shifting problem
zepplin153
shifting problem
when I get a wide open area and I start blasting through the gears when I get to 4th it has a hard time shifting from 3rd and 4th and just wants to stay in 3rd. I will usually have to end up letting off the gas a lot in order to get it to shift. Any ideas?
'98 KDX 200 (KLX300 Forks)
zepplin153
- Has thanked: 10 times
- Been thanked: 17 times
Re: shifting problem
That's probably the most obvious cause. Does the clutch seem to drag the engine? If it's not the clutch, it's possible that a shift fork is bend. No fun there, so we will hope not!
J
J
- rbates9
shifting problem
My 200 starts to shift funny / hard when the oil gets worn out. Might be worth changing the oil. Maybe even trying a different oil.
I could see the clutch basket being an issue but if you are trying to shift with out the clutch then a notched basket will not matter.
- scheckaet
shifting problem
dirty oil, wrong oil, worn out clutch...
try changing the oil and see how it goes.
What are you using?
What are you using?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
