amsoil interceptor oil
iceman0074
I've been running the amsoil interceptor at 32-1 last night I was on the am soil site and it said recommend at 50-1 so I mixed up 5 liters and wow the bike cane to life so my question is...... why ...... Should I keep err running it ..bike has stock jetting as far as I know I've only owned the bike for about 4 months happy trails everyone
- Has thanked: 9 times
- Been thanked: 17 times
Re: amsoil interceptor oil
Probably better to stick with 32 or 40 and actually jet the thing. Should make more power that way.
Sent from my HTC6435LVW using Tapatalk 2
- Postigo
Look like you are running lean. If your bike runs better with 50:1 that means you have 50 parts of gas per 1 part of oil. Your bikes engine was design for 32:1 so less oil is equivalent to more wear.
iceman0074
Why would ams recommend 50-1 and I understand kdx are 32-1 according to the manual But out of the 7 types of mix they say to use they also don't say anything about synthetics I have some non synthetic 2t oil and it is thinner I find ams synthetic thicker ...I'm just trying to figure out why my bike is running so much better ...maybe I'll take the carb off and see what jets are in it maybe the previous owner changed them he was also using ams just not sure the mix
- Has thanked: 52 times
- Been thanked: 18 times
Your jetting was off before. It may be still off, just not as bad as before.
50:1 is what Amsoil recommends. 50:1 sounds like putting around, following a child rider type of oil ratio. The more you twist the throttle, the higher amount of oil you will need.
Pick an oil, figure out whih ratio your riding type requires, then jet accordingly. Swapping brands of gasoline, dirty air filter, etc. will throw off jetting.
Take your jets out, see what they are, then start making changes one at a time.
iceman0074
OK took the jets out I believe they are stock I decided to run 40-1 next week its going to the bike shop to get tuned and jetted for 40-1 and right now the air screw is out 2 turn but seems to run fine plug is between light and golden brown any thoughts
YOU REALLY NEED to learn to do this yourself.
iceman0074
I'm trying to learn think I read every kdx carb jetting on the net but tx for letting me know I need to learn that's kinda why I'm on this forum thanks for all your help I've learned I need to learn
- Postigo
Here is what you need to know about jetting.
http://justkdx.dirtrider.net/printcarbtuning.html
