MX Style Front Fender
RockCrayfish
Post by RockCrayfish »
Hi All,
I've placed an order for a Maier rear fender for my 06 KDX 200 but I'd also like to find a suitable front fender that requires no modification (a direct bolt-on).
Preferably an Acerbis Fender that has a arrow/spade shape. Similar to this (that's a 2005 KX fender of some sort):
Been thanked: 2 times
Pretty much any KX fender will work fine. Any front fender from about any full sized bike can be easily made to work.
RockCrayfish
Re: MX Style Front Fender
Thanks bates (can I call you bates?!). I ordered an Acerbis mx style for 2003-2007 kx125/250, hoping it's a direct bolt-on. I don't mind modifying but I want it to look as clean as possible.
That should work. If anything you may have to open the mounting holes up a bit or drill new ones. Either way it will never be seen once it is on the bike.
RockCrayfish
rbates9 wrote:That should work. If anything you may have to open the mounting holes up a bit or drill new ones. Either way it will never be seen once it is on the bike.
Excellent, that's what I was hoping to hear.
Has thanked: 195 times
Been thanked: 52 times
Can you measure your front fender distances between the holes? I have the fender off my KX125 and am curious to see if they are the same. Thanks.
factoryX
Post by factoryX »
I bolted up a kx450f fender to stock triples with no problems.
diymirage
Post by diymirage »
Jason wrote:Can you measure your front fender distances between the holes? I have the fender off my KX125 and am curious to see if they are the same. Thanks.
When I bought my KX front end it came with a fender (99) and the only difference between that fender and the KDX one is the guide for the odometer drive
Hey. Thanks for letting me know.
