Tips for fork seal replacement
Posted: 09:41 pm Sep 10 2012
by Dekon
Anyone have any tips for doing the fork seals on an E series?
Posted: 04:50 pm Sep 11 2012
by david
Nothing special. Typical standard forks. It helps if you have a parts washer and air tools. A 3/8 impact on the lower bolt that holds it all together makes easy work of it.
Posted: 08:10 am Sep 12 2012
by gsa102
USE WITH CAUTION!
A trick I learned for conventional forks is to remove the seal retainer clip, then put compressed air into the fork through the bleeder hole to push the seal out. Then you don't have to disassemble them. If the seals stick then pour hot water over the seals to soften the rubber and try again.
Hold a rag over the seal so oil does not go flying when they come out.
I was going to replace the fork seals on an 81 MX 100, but could not disassemble them and they wouldn't come out with air pressure. So I used a thin plastic seal cleaner tool to clean the seals, and filled with fresh oil. No more leaks. I was amazed!
Re: Tips for fork seal replacement
Posted: 11:28 am Sep 12 2012
by Dekon
Great tip. You mean the bleeder on the top of the fork tube and not the drain on the bottom, correct?
Posted: 09:34 pm Sep 12 2012
It is 10mm or 14mm on the base valve (compression adjuster assembly).
Posted: 03:33 pm Sep 13 2012
by david
If that is all you want to do is replace the seals and not clean them out, I have used two of those very sharp sheet rock screws. Tap them into the seal with a hammer then screw them in a little. Use some side cutters or pliers to grip the screw and lift the seal out of its seat.
Posted: 04:44 pm Sep 13 2012
by Dekon
Yup, all I want to do is replace the fork seals and oil.
Posted: 06:53 pm Sep 13 2012
You won't be able to clean out all the gunk and residue if you don't separate the tubes.
Posted: 08:29 pm Sep 13 2012
by Dekon
Jason wrote:You won't be able to clean out all the gunk and residue if you don't separate the tubes.
Crap!
Posted: 05:29 pm Sep 14 2012
by david
It's not that hard.
Posted: 11:02 am Oct 20 2012
by RailwayRog
gsa102 wrote:USE WITH CAUTION!
Okay I did this and it worked, great.
But now how do I get the correct amount of oil back in the fork tube?
I lost oil from the leaking seal and using this method.
Posted: 10:52 am Oct 30 2012
by mud99
Remove top cap, dump out oil by cycling the shock upside down over a bucket, remove spring.
Use air impact tool to loosen bolt on bottom of shock using short high speed bursts.
Remove dust seal from fork body. Remove circlip. Hammer fork tubes from fork body by forcefully extending shocks with a slide hammer type of motion.
Everything should be obvious at that point.
by mud99
As far as the oil, you need a fork oil tool.
Posted: 07:22 am Nov 02 2012
by Steve_K
A good tip when taking seals out. Is to heat the outer tubes up so the seals come out easier.
Posted: 10:15 am Nov 02 2012
by scheckaet
mud99 wrote:As far as the oil, you need a fork oil tool.
no you don't.
need a syringe, some tubing and a straw...
