Loosing Coolant
Posted: 11:06 am Jul 28 2012
by asmed12345
I don't remember exactly when it began, but each ride when I return home, my coolant is depleated greatly. I havn't noticed it leaking anywhere but maybe it has when i'm riding. Has anybody else had this problem? I know coolant is a closed system so I shouldn't be loosing it which worries me. BTW its an '02 KDX 200.
Re: Loosing Coolant
Posted: 02:15 pm Jul 28 2012
by KDX200Diesel
do u have water in tranny??? is most likely cause water pump seal or ive notice on by bike when i pop wheelies coolant comes out of reservoir tank but not that much
Loosing Coolant
Posted: 03:14 pm Jul 28 2012
by ss109
If you have no water in your trans then you are probably losing it through the radiator cap. You probably just need a new cap. I had a similar problem due to high temps because of the auto-clutch/AZ heat so I replaced the standard 1.1 cap with a 1.6 and no more coolant loss.
Loosing Coolant
Posted: 04:11 pm Jul 28 2012
by rbates9
If you have your bike jetted a little lean then it may be getting hot and pushing it out the overflow as well. After a good hill climb or a tight spot pull off and see if the overflow tank is flowing. Another thing could be a head gasket.
Re: Loosing Coolant
Posted: 12:34 pm Jul 29 2012
by CoronasAndChips
How bent up are your radiators? You could have a split seam or a broken row. Get a pressure tester and look for the leak. You could rent one at an auto part store for cheap. Also if it's a decent size leak there should be a stain/grime build up from the coolant.
Re: Loosing Coolant
Posted: 05:29 pm Aug 04 2012
by CoronasAndChips
Any updates?
Loosing Coolant
Posted: 02:09 am Aug 06 2012
by Mr. Wibbens
**** I add water to mine throughout the ride
Loosing Coolant
Posted: 02:56 am Aug 06 2012
by Brian
I haven't needed to add any colant since I did my top end a couple years ago.
Loosing Coolant
Posted: 07:43 pm Aug 06 2012
by CoronasAndChips
Mr. Wibbens wrote:**** I add water to mine throughout the ride
Seriously? Or don't you have a recovery bottle?
Loosing Coolant
Posted: 09:50 pm Aug 06 2012
by ss109
I don't have a recovery bottle and have never needed to add coolant during a ride. The only time I have lost coolant was when my water pump seal failed a year before the rebuild and once since the rebuild running it hard with Dyna Ring. Both were easy fixes, a new seal for one and a 1.6 radiator cap for the other.
