So I think I finally have proper jets in my bike, but...
Posted: 05:00 pm May 05 2011
by KDXrider1989
It still feels kinda sloppy whenever I get on the throttle. Main jet: 155, Pilot: 42, R1369N needle in the 2nd position, KIPS works smoothly and the motor still has good compression. If I wanted to lean things out a bit, is it okay to alter the float level? Seems like whenever I go to an MX track and land a few jumps, the bike acts completely different and has a much stronger powerband and better throttle response, even right off idle. Could it be the float level that's causing this?
Posted: 07:25 pm May 05 2011
by rbates9
It could very well be a float issue. Have you played with the air screw much?
Posted: 07:35 pm May 05 2011
by KDXrider1989
yeah, I'm at 2 turns out right now. I went by Vince's jetting guide, I'll see if backing out the air screw would make a difference, last time I tried it didn't but that was when it was nearly 50 degrees outside and when I had a slight carb leak
Posted: 07:48 pm May 05 2011
by rbates9
Might be worth going in and see what it will do also. The jetting guid will get you very close but you may have to fine tune a little from there.
Posted: 10:11 pm May 05 2011
by KDXrider1989
Also, would it hurt if I were to change the float height? Maybe a millimeter or two, I really liked the way my bike was performing at the track (if the float valve is the cause, I'm pretty certain it is) besides, I think my bike is running a little rich
Posted: 05:46 am May 06 2011
by rbates9
Try it, You can always go back.
