2000 RM set up
jrnolan
2000 RM set up
Post by jrnolan »
2000RM 250
Any thoughts on this swap on my 96 KDX? Same as KX forks/clamps of same year?
Thank you,
JR
kdxtreme
Post by kdxtreme »
I just did a 2001 rm 125 setup the twin chambers rock are those open chamber kyb's.
Did I say riding?
froggy
Post by froggy »
How hard was it to use the 2001 rm125 forks. I found a set 2001 rm 125 forks, triple clamps, wheel, brake assy, I was thinking about using for a fork conversion.
jrnolan
Post by jrnolan »
kdxtreme wrote:I just did a 2001 rm 125 setup the twin chambers rock are those open chamber kyb's.
I don't know I am trying to find out.
Has thanked: 15 times
Been thanked: 27 times
should be pretty much the same as the kx swap.
jrnolan
Post by jrnolan »
Thank you.
kdxtreme
Post by kdxtreme »
Its the same the forks work great i had mine revalved and sprung for my weight.
Did I say riding?
Smoke
Post by Smoke »
Are you guys saying the whole complete front end will bolt up like the KX? Triple trees and all, just basically swap stems/spacers out?
Thanks in advance!
right. Pretty much holds true for any complete front end, as long as the KDX stem can be swapped in. I'm using a yz front.
