Steering Stem bearing Race removal
ditton
Post by ditton »
Hi there.
Just got all my parts together and gonna start with fork swap.
Just wondering if anyone has any good ideas on how to remove/install the steering stem bearing race (top/bottom) with just general tools?
Have a punch to get them out but putting them back in level seems like it might be the tricky part.
Thanks in advance for any info
Ditton
Just use a brass punch, get it going in and keep driving it back and forth until it hits solid. The sound will change when it has seated.
ditton
Post by ditton »
Thanks rbates9.
Will give that a try. Hoping they come out easy without having to heat them up.
Thanks
Ditton
Heating the race will make them come out harder. They should come out with out heat. Just go back and forth, side to side. They should come out pretty easy.
Mr. Wibbens
Post by Mr. Wibbens »
They come out easy with a drift
I tap them back in with a hard plastic mallet
Or get them started and use the old race to drive them in with a hammer
ditton
Post by ditton »
Yep...they came out pretty easy.
Set the new ones back in using a rubber mallet then finished using the old races to set them.
Thanks
Ditton
Mr. Wibbens
sweet :wink:
diymirage
Re: Steering Stem bearing Race removal
Post by diymirage »
(in order not to start a new post on an existing topic im reviving an old post)
i wasnt planning on redoing the bearing but Ron advised me to so i will, long story short, is there a difference between the upper and lower races ?
or is this a question that will awnser itself when i go to tap the old ones out ?
Has thanked: 153 times
Been thanked: 38 times
Yes, they are different sizes. Try to keep the races paired up with the bearings they came with.
For example, don't use new bearings with old races.
diymirage
Post by diymirage »
great
i should have no problem then
cant wait to get the bike back on the road, it hasnt sat this long since ive owned it, and that includes a michigan winter
