Thanks to all of you for your advice.
kdxmaniac
Post by kdxmaniac »
well............dont call bs on somebody, and cant back it up.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Budget_89KDX
Post by Budget_89KDX »
Lmfao...you didn't answer my questions.I don't care about ci I asked how you able to safely run those c/r's and what headss you're running.you acted like it was a big secret and gave me a half assed vague answer.
My current engine is just a little bitty 302 and 150shot of spray and has went 7.57 in the 1/8 and I drive it almost 100 miles round trip to the track something I'm guessing you can't o with that 347?
Budget_89KDX
Anywho bro thanks for the advice and help on the kdx so far its been greatly appreciated.I figured id be ok running 87 since the info I found on these kdx's say theyre something like 7:5.1.
David_L6
Post by David_L6 »
Indawoods wrote:If it isn't pinging... don't worry about it. You would hear it....
There ya go!
I run 100LL AV gas in just about everything other than my truck. The two CR250s have had the heads modified by RB Designs. I'm going to send the KDX head and carb to RB along with triple clamps, stem, etc. as soon as I can afford to. (Keeping up 5 dirt bikes and 2 ATVs isn't cheap!) I haven't checked the compression on anything. When I send a head to RB I ask him to set the compression for AV gas. I have no idea what compression numbers I am getting on anything. I haven't checked.
kdxmaniac
Post by kdxmaniac »
Budget_89KDX wrote:Lmfao...you didn't answer my questions.I don't care about ci I asked how you able to safely run those c/r's and what headss you're running.you acted like it was a big secret and gave me a half assed vague answer.
my motor is a little bit of a secret! i told you what heads, and head gaskets im running...."I' have never got a head gasket!....i quess i know a little more about compression and detnation :hmm: :grin: ....my old motor in the black gt in the video has run a best of 6.98 in the 1/8.......STOCK bottom end on a 125 shot, in the video it went a 7.15 on a 90 shot! all in a STOCK suspension STREET CAR, full interior....that is daily driven......and btw, who cares if i can drive my car 100 miles? i have other cars that will! i also have a 79 t/a 4 speed car that will run the 1/8 at a 7.60 on motor, on street tires, and is daily driven and your the one that called bullshit on my car! i wasnt try to be a smartass, like i said, i did answer your question, your asked what heads, i told you afr 205, you asked what head gaskets, i told you cometic mls......why should i tell you more? as far as you not seeing anyone running these compression ratio's and lasting??? i dont know what to tell you.....i know of alot of cars running more than me and dont have a problem, like the white lx that shands on the bumper in the video, and gets out of it......he is running a small block ford, with 12.1 compression with a 500 shot fogger, and a 200 plate!!! makes 980 hp AT THE TIRES! on just the 500.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
fuzzy
Post by fuzzy »
.I rode it for maybe half hour today before work and I didn't hear any detonation and it fires up on the first kick.how much do these thin gaskets raise compression?
Yep, no ping, no worries. .008 isn't that much....You can only do so much with a gasket. Most run 93. Non-eth is generally available at a marina, BTW.
Now I do call bull **** on a sbf under boost running (atleast for very long) of any kind running a 12:1 c/r.bro I've raced every year for over 10yrs and am ford certified and was a tech for years before and after the military and mustangs mostly have been my choice to build off of and have owned 27 different 79-93 fox bodies with countless engine combos and have yet to see one go that high with 6lbs and spray not spit the head gaskets constantly even o-ringed.what type of huffer you using and at those c/r's how often you putting head gaskets in it?also what type of heads you using?I run 1/8 what do you drag?
In another post he says 11.1:1. You need to get to some bigger races I think :cool: These types of combos are common and live well, but generally with electronic fuel/ignition management only, and with proper modern cam selection. It certainly doesn't take much to make them pop. It's VERY wise to data-log, and creep into the tune. Budget, I'm not trying to dog you, but it's odd to tout such a resume, but ask such a question. You should know that getting all the compression you can, on your desired fuel is a good thing. The only evil in this equation is detonation. 2-cycle detonation will sound just like 4-cycle detonation...A rattling noise...Just a lot more rapid (motor is turning close to 2x the RPM)...Light if your lucky. VERY light detonation can generally be heard easier from an onlooker with a keen ear on the exhaust. On a silenced 2-cycle, believe me you'll hear it. Sounds like you are all good to go.
BTW, I'm crewing for the green stang this year...Can't wait! Last car (drag radial F-body) was a 13:1 406 SB2 with 2 huge kits, FAST injection, 6000rpm glide, and 7530T ignition. The ignition/fuel feed/fuel selection is everything. None of us are really engine builders....We leave that up to the best when it comes to this crazy stuff. We're OK at it though, and have to be able to tune it of course. The new tech is nuts. New 450" SBF car has same ign, twin 88's, and a liberty, and it's still a bit like bringing a knife to a gun fight. :shock: Hopefully we'll do OK, and not break much...esp the motor!
http://www.dragzine.com/news/pritchett- ... -5-effort/
I should be at PRI right now damn it....Friggin work. :mad:
kdxmaniac
Post by kdxmaniac »
thank you fuzzy!! :supz:
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Budget_89KDX
Kdx ur full of **** bottom line!everyone and their brother Knowes a 302 is only for 550hp at best go online and look at the forums littered with pics of overdone sbf's split down the middle!now I'm not going into this anymore because this is just a **** swinging contest!
and this was started because of..."Thanks to all of you for your advice".
:rolleyes:
Been thanked: 2 times
But the real question is, who's dad can beat up who's dad?
kdxmaniac
Post by kdxmaniac »
>|QBB<[/url]
Budget_89KDX wrote:Kdx ur full of **** bottom line!everyone and their brother Knowes a 302 is only for 550hp at best go online and look at the forums littered with pics of overdone sbf's split down the middle!now I'm not going into this anymore because this is just a **** swinging contest!
you got it wrong.........what do i need to prove to you? who said i was running a stock block????....................anyway, what color is the moon :butthead: .........where do you get that im full of ****? YOU are the one that called bs on my car, and YOU are the one that asked what heads, and gaskets i run, and i told you........why are you getting so mad when your wrong? you do know we build drag cars for a living, right?
now quit calling bullshit on me, and quit telling me what i have in my motor, and quit telling me im full of ****!!! you need to wake up.......or get off the wacky weed :shock: if you say i CANT run 11-12.1 on 6 psi boost..........and if your running a mid 7 in the 1/8, what are you tring to tell me? ........now go ride you kdx and have fun!!!!!!
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Budget_89KDX
Ok if you're not running a story k block I retract my statements and appologize.I was under the impression you were running a stock block.so again I appologize.and I am still thankful for your help bro.no hard feelings.
kdxmaniac
Post by kdxmaniac »
what is a k block????? the stock 5.0 block is either a y or x block. but anyway, theres no hard feelings............and assuming around where i live is what causes you loose money on a race! :wink:........never assume, especially with me, i tend to "not tell the whole story".....and you have to be really specific on what you ask, because thats all im going to answer"may not still be the whole truth!" :lol: .....thats why its called stock suspension "grudge" racing.....in other words........lets say your running a 6.50........ill back out of my car and run a fender ahead, and run....oh say a 6.48.....then someone with a 6.20 car will want to put money on a race, thinking i run mid 6,..........well, they assumed and lost there money.....get it now?? forget eveything FORD tought you, if you think about it, nothing that is built like our cars, dont have a ford/chevy/mopar? part left in them, it all aftermarket!!! like i said, i wasnt being a smartass, i just dont see giving info for no reason, and you was the one trying to tell me what i had, and couldnt run. :doh: .........
oppologe exepted :partyman: "i know its spelled wrong!" :roll:
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
