Thninking of 10-11 Tooth Front with 52-54 Tooth Rear
13/47
- fuzzy
Similar reasons are why people do to the back (+3 = ~1 front) when re-gearing. The 13T is less prone to wearing itself out, and the chain too. On the bright side it's a piece o cake to put on and/or switch back and forth.i run a 12 front, stock rear........geared just right. i can ride tech. stuff in 1st, and still climb hills in 2nd and 3rd.........i dont think i would go smaller on the front than a 12......im sure the chain will rub the case.
- Velocity_Stack
Rear +3 ~ -1 front <------ that's good to know.fuzzy wrote:Similar reasons are why people do to the back (+3 = ~1 front) when re-gearing. The 13T is less prone to wearing itself out, and the chain too. On the bright side it's a piece o cake to put on and/or switch back and forth.i run a 12 front, stock rear........geared just right. i can ride tech. stuff in 1st, and still climb hills in 2nd and 3rd.........i dont think i would go smaller on the front than a 12......im sure the chain will rub the case.
- David_L6
- Velocity_Stack
swatts wrote:I run 12 and 51, thought that was the lowest you'd ever want, I ride very gnarly, technical terrain, the engine keeps running for sure. I was worried about the chain guide but it was fine. Go for it.
Do you think I could squeeze a 52 with the stock chain guide?
If not, does anyone have any input on a aftermarket chain guide that would support a 52t rear?
