double post?
Well, to the op...
Since you're game to fix it, I'd look for a set of cases second hand in good condition. After that, rebuild as normal going through bottom and top end. I'd do the same if it were my bike. Why do I wanna shop for another when I love what I got?
Bought A 2001 220. Need opinions!!!
Yeah...but it won't leak. Have a little faith!!
Of course the preferred option would have been for Ms. Piston to keep her skirt on in the first place, but we're not in Virginia any more.
The guy says he can weld it...so go for it! What is there to lose?
Nothing in my bike......
Is it fixed yet?
Is it fixed yet?
RB designs rebuilds cranks for $35.juliend wrote:Hmm. I'm not even sure a very good aluminum welder can fix that. There's very little clearance inside between the case and the crank, and that section of the case does hold compression. If it were mine i'd be after new or used cases.
Anyway, assuming you can fix the cases you're looking at....
Welding case
Rod kit ~90
main bearings seals ~50
wiseco piston kit ~130
replate cylinder ~200 (if you're lucky)
Labor for crank rebuild ~60
If you can split the cases and do the rest of the work yourself, you can get out pretty cheap. A shop is going to charge you a few hundred, easy.
J.
- Has thanked: 5 times
- Been thanked: 12 times
Slick_Nick wrote:RB designs rebuilds cranks for $35.juliend wrote:Hmm. I'm not even sure a very good aluminum welder can fix that. There's very little clearance inside between the case and the crank, and that section of the case does hold compression. If it were mine i'd be after new or used cases.
Welding case
Rod kit ~90
J.
Right. And I guess you're gonna ship it there and back for free?
Like I said. Around $60 by the time it's said and done, whether you do it locally or send it off.
Right. Is this coming down to simple math?Slick_Nick wrote:It doesn't even cost ME $25 for shipping to RB and I'm in Canada. Try $10-$15 for the US folks.
$10 shipping crank to RB (good luck getting it there safe for $10, but I'm being generous here)
$35 labor to rebuild
$10 - $20 to ship it back? No, Ron does not ship it back for free.
Does that add up somewhere near $60? Would it make you feel better if I said it would be somewhere around $50?
Someone's always gotta be a wiseass.
Don't make me pull over!
