Is the KDX tractor like?
Ed5786
Re: Is the KDX tractor like?
I run 13/49. With the fmf woods pipe, there is plenty of pull from bottom to top. I also have the desert pipe, and much prefer the woods. IMO, the desert gives more up on the bottom than the woods does on top.
1998 KDX200
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Fmf gnarly woods
Boyesen reeds
13/49 gearing
firsthere
Good to know, I have the desert pipe also and it does lose some low end compared to the stock anchor.
PC seems to be the best of both from what I have read?
Ed5786
I had thought about a pro circuit pipe as well, and people who have it said it wasn't all that different than the desert. Same mid range hit and top end and maybe just a little more on the bottom. Having the woods pipe is almost like riding with an auto clutch once your jetting is dialed. Handles slow twisty stuff with ease and makes sand/hills a breeze.
1998 KDX200
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Fmf gnarly woods
Boyesen reeds
13/49 gearing
- G22inSC
I have the PC Platinum II and love it but be warned, it's no longer in production. They are not hard to find online now but eventually the supply will dry up and our only choice will be a FMF version.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
BamBam
From reading around here, I though the PC pipe sounded best for a 220. The only thing is that some say it sticks out very far and is sure to get dented in a fall. How much of a serious concern should that be???
firsthere
Can you elaborate on how the PC II affects the power output on a stock 200 (2004)?G22inSC wrote:I have the PC Platinum II and love it but be warned, it's no longer in production. They are not hard to find online now but eventually the supply will dry up and our only choice will be a FMF version.
Only other mod is two stage reeds which made small gains everywhere including more top end. No powerband to speak of though.
- G22inSC
Sad to say but don't really know. That was one of the first mods done right off the bat so I don't know what it was like compared to stock. I put the PC pipe on before the motor was even broken in. I've always heard the Platinum II is a more all around pipe with a little power added everywhere. It is supposedly still better than stock on the bottom, great mid and can still rev. It seems the FMF pipes are much more either low end or top end focused.
'08 Kaw KX65 (Sold)
Gallery
'08 Kaw KX65 (Sold)
Gallery
firsthere
Yeah, that's my thoughts also, a good all around pipe. Does your bike have a powerband/hit with the PC? Not that that would be a problem up high, I think having a powerband makes the most of a two strokes potential.
- G22inSC
Yes, there is a powerband. The "hit" can be tuned depending on what style you like.
'08 Kaw KX65 (Sold)
Gallery
'08 Kaw KX65 (Sold)
Gallery
Friedom
Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
It's a dog until the powerband hits. Then it'll throttle wheelie in third going downhill!
Ed5786
KIPS functioning alright? From what I've read the E series bikes have a little more bottom end than the later model H series. I have also read the sub valves like to break.Friedom wrote:Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
1998 KDX200
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Friedom
KIPS is working superb. I have the BDK steel KIPS valves in it. It's when they open that the bike runs so well.Ed5786 wrote:KIPS functioning alright? From what I've read the E series bikes have a little more bottom end than the later model H series. I have also read the sub valves like to break.Friedom wrote:Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
Ed5786
Good compression? When I bought my bike, I though it ran pretty good. Then I did a top end and all of a sudden I had a lot off off idle pull.Friedom wrote:KIPS is working superb. I have the BDK steel KIPS valves in it. It's when they open that the bike runs so well.Ed5786 wrote:KIPS functioning alright? From what I've read the E series bikes have a little more bottom end than the later model H series. I have also read the sub valves like to break.Friedom wrote:Boy, after reading this I'm wondering if I need to go back to the drawing board on tuning my 92 200.
1998 KDX200
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Friedom
Brand new engine (top and bottom) build with a fresh nicasil lining from Millennium Tech, ported and polished. When it comes on the pipe it's extraordinary, it's just really lame before then.
Ed5786
If it's all jetted properly maybe the porting just changed the nature of it?Friedom wrote:Brand new engine (top and bottom) build with a fresh nicasil lining from Millennium Tech, ported and polished. When it comes on the pipe it's extraordinary, it's just really lame before then.
1998 KDX200
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Fmf gnarly woods
Boyesen reeds
13/49 gearing
Friedom
That could be. They did an "all around" porting. I bet an air Stryker and an RB head would do wonders for it. I'm also running a rad valve. The old carb is probably the bottle neck, I've just thrown so much money into this bike that if I can't tune it out, it's probably going to stay in :)Ed5786 wrote:If it's all jetted properly maybe the porting just changed the nature of it?Friedom wrote:Brand new engine (top and bottom) build with a fresh nicasil lining from Millennium Tech, ported and polished. When it comes on the pipe it's extraordinary, it's just really lame before then.
