Re: Triple tree steering shaft threads
Posted: 02:31 am Dec 16 2016
Ok thanks guys! I went back out in the freezing cold garage and checked it out again and the KX500 and KDX shaft are the same diameter. I just need to shim the upper triple up.
You cant see in the pics but there are exposed threads above the lower nut holding the upper triple above the lower nut so there is a even bigger gap under the upper triple.
My idea is to have my extra lower nut milled down so it will thread on top of the remaining threads and work perfectly as a spacer.
