Page 2 of 4
Re: My first KDX (200 96)
Posted: 12:46 pm Jan 31 2015
by diymirage
Beer! wrote:BTW, I am a fan of your countries beers! I plan on doing a brouwerij tour there in the next 2 years with some friends.
their beer and their chocolate are among the best in the world, and their food in general is great
its amazing they do not have the obesity problems the US has
but im not sure if Cedric knows what a brouwerij is, if I remember correctly he is from the wrong (read, French) part of Belgium
Posted: 01:51 pm Jan 31 2015
by ced64k
I don't drink alcohol at all, only chocolate :D But if you like that, I think I'm in the right part of the country (Maredsous, Chimay, Floreffe, Saint-Feuillien, Leffe, Rochefort, Orval, ...)
http://en.wikipedia.org/wiki/Beer_in_Belgium
Posted: 03:09 am Feb 01 2015
by Beer!
Oh my, I am envious!
Posted: 07:40 am Mar 17 2015
by ced64k
I dismounted all spokes from my KX 250 97 front wheel before painting. I noticed that the rim is slightly bent on 4-5 cm.
I wondered if I can mount the kdx rim on the kx hub ?
Posted: 10:23 am Mar 17 2015
by 6 Riders
ced64k wrote:I dismounted all spokes from my KX 250 97 front wheel before painting. I noticed that the rim is slightly bent on 4-5 cm.
You can, the rims are interchangeable. Just an FYI, my wheel guy straightens rims out while by truing the wheel. You can try that as well.
Posted: 08:40 pm Mar 17 2015
by Jaguar
thoughts about replacing the stock front forks with ones from a KX should be reserved for very good riders that are racing (enduro, cross country, desert, motocross). Damn, I used to motocross a '89 KDX200 with stock forks and after a spring and oil change I had no complaints with the forks. The shock was another story. I eventually replaced it with an Ohlins shock. That rear suspension was a total wet dream. OMG !
Posted: 08:46 am Mar 18 2015
by ced64k
6 Riders wrote:Just an FYI, my wheel guy straightens rims out while by truing the wheel. You can try that as well.
Yep.
It's more clear with a picture :)
Posted: 09:28 am Mar 18 2015
by 6 Riders
So that can be fixed, or....You can use the KDX wheel with the KX spokes, but, IIRC, the holes on the KDX wheel will have to be drilled out a little bit.
Posted: 01:47 pm May 03 2015
by ced64k
I just noticied that my 97 KX125 upper triple is different from the 250. The 125 triple is molded in one piece:
And on the 250 the bar clamps are separated:
Can it be problematic on the KDX ? The KDX triple was also with this rubber thing. I presume it's made for reducing vibrations ? Maybe it can also limit the handlebar choice ?
Fortunately the lower triple is the same.
Posted: 03:51 pm May 03 2015
by 6 Riders
I prefer the solid mounts, as they don't twist in crashes.
Posted: 01:15 pm May 13 2015
by ced64k
Little update with some parts back from powdercoating
Posted: 05:08 am May 14 2015
by Bitteeinit
Very nice.
Posted: 12:33 pm May 19 2015
by ced64k
Villopoto style
Posted: 12:48 pm May 19 2015
by 6 Riders
What colors did you use on the swing arm and frame? Where did you get the seat cover?
Posted: 01:08 pm May 19 2015
by ced64k
RAL9007 (powdercoating) and
Ebay for the seat cover.
Posted: 08:32 am Jul 30 2015
by ced64k
My suspensions are finally back !
Full rebuilt with Kayaba kits, forks tuned for enduro with Marzocchi 0.38 springs and shortened by 3cm to avoid the chopper effect
Posted: 01:27 pm Aug 23 2015
by ced64k
I replaced my swingarm bearings (All Balls) but they don't turn freely by a finger. Is it normal ?
Posted: 07:57 am Aug 29 2015
by ced64k
I dismounted the new bearing and it's not good
For the exterior bearings it 's ok, the sleeve enters freely but for the interior bearings I have to force. This is why the sleeve won't turn. The combo All Balls cheap chinese bearings + young mechanic in the neighborhood was a bad idea.
Now I reassemble the forks. But I'm not sure, is the proper mounting ?
Posted: 01:39 pm Jan 19 2016
by ced64k
UFO Stealth headlight
Re: 96' KDX200 rebuild
Posted: 10:14 am Jan 20 2016
by Tyl3r
I just powdercoated my hubs gold as well! haha What color did you use for them? I used Sun Gold on mine. Everything looks good man, should be pretty awesome when its done! Where are you getting the spokes and nipples from? I am having a hard time finding gold nipples and black spokes.
