l think lm blushing
That took some work !
The repair was visible through the black primer but not the hi temp grey but the grey didn't stick to the alloy like the black did.
So it was a layered combination of both. When l rubbed through to alloy the black went on and if l didn't, it was grey which went on thicker without running.
There's a kv100 down the back of the shed
Its contribution is the clutch and brake lever perch's, they have mirror mounts.
When l first saw this l thought l had done some poor blasting.
The engines painted, now just walk away and let the paint dry
l have 9 different tins of black paint on the shelf and l mainly use 3. Frame and bits black, switchgear black and engine & exhaust black which is this hi temp stuff. l use this primer on everything except the hot stuff.
Minimising the risk......
No problems there. The fin repair is on this side.
The wiring transfer from the parts kdx250 starts now. l have plenty of other things to do but lm happy to be fitting things onto the bike now rather than putting parts on the shelf for later. The wiring may be the sort of job l want to walk away from regularly
The kick start lever hits on the head and has caused some damage. On one spline it hits the head but moving it back a spline it sits.... untidily. l have a 175 lever that sits just right as the spline is in a slightly different spot but the knuckle is smaller than the 450 so I'll swap the knuckles over but the O rings are in different places. l might just use the 175 lever and take the other one as a spare.
Restored perches with mirror mounts. None of these parts are original to the 450 but came from the depths of the shed...
for these mirrors. Just bought them from our friends at eBay and as they're in Australia, the postage is very reasonable
The wiring is very simple on the 450, there's not much to it with basic lights only. lm not sure yet if the 250 wiring will replace this wiring or work around it.
This doesn't look very simple at all
It doesn't look that bad off the bike. There's 3 plugs on the front of the loom for the ignition switch, switchgear and headlight.
The wiring loom cleaned up well. The original piece of white tape with the loom part number is still attached and sits on top of the airbox. The air box fits well with only the top mount in the box needing a small spacer between it and the mount so the airbox lid/sidecover fits well with no gaps. My repo sprocket cover arrived today, its a faithful copy of an original.
There looks to be enough room under the tank for the resistor and flasher can to fit, at least without the pipe fitted Grin. I'll need to fashion a bracket to mount them.
The wiring sits well under the tank. With the pipe on there wont be much to see.
