How much compression
Jaguar
Country: Ecuador
Been thanked: 2 times
Re: How much compression
Post by Jaguar »
"The H seems more responsive and snappy in the upper RPM range, while the E bike has a smooth and harder pull from the bottom. That would indicate the opposite of what these numbers are showing, yes? "
That sounds right to me. Higher compression is more advantageous for mid range power.
Has thanked: 10 times
Been thanked: 17 times
All else being equal, the higher compression in the H model engine should give it stronger pull from low range up to 6k RPM (when the kips activates). In my experience, it does not. The E engine will walk all over the H until getting into the very top end of the RPM range. That's just personal experience of mine from riding both. YMMV.
C George
Post by C George »
Great collection of bikes !!
200 PSI ,,,, WOW ,, Thats an awesome top end for a KDX.
C George
Post by C George »
Julien D wrote:All else being equal, the higher compression in the H model engine should give it stronger pull from low range up to 6k RPM (when the kips activates). In my experience, it does not. The E engine will walk all over the H until getting into the very top end of the RPM range. That's just personal experience of mine from riding both. YMMV.
The E model has the higher compression .
And I believe it would pull so much better than an H below 6000 rpms.
C George
Post by C George »
Has anybody ever measured how they got the extra compression ?
Is the head that much different ? Cylinder shorter ? Thats quite a difference in numbers.
The E model has a higher "usable range" as stated in the manual, however, it has a lower compression ratio. At least for the "low speed" rating. This is obviously conflicting information.
C George
Post by C George »
I may be wrong but I believe the compression psi number higher on the E is what you feel.
Compression ratio's are confusing and very hard to really measure on a two stroke.
What they'll push for pressure out the plug hole seems to be key.
But ,,, I've been wrong before. :? :?
No, I agree with you. In my experience the E will test at a higher PSI, and that would explain the gain in low end power. After a replate/rebuild my E was at about 170 PSI. I just question the published numbers as far as compression ratios.
C George
Post by C George »
I'm in the middle of a new 220 top end for my son's 200 and am sending the head off to RB.
To get 190 -200 psi of compression , I asked for a "race gas " head.
But as I've commented before , I have no problem blending in AV Gas to have a TRUE 95 octane fuel.
A conventional 220 head reworked should make 170-175 psi.
