LED Headlight installed
rsr02
Re: LED Headlight installed
Post by rsr02 »
I was thinking about the A/C thing and came up with this. A LED is basically a diode, meaning if the a/c power going into it is +-+-+-+-+- the led is only lighting up on the pluses. Meaning, I think, that the photo above is the light only running on 6v dc. Of course I could be completely wrong. Either way I am going to give the LED headlight a shot.
1997 220, KLX forks-pipe-reeds-trials tire
Roadhazardguy
Post by Roadhazardguy »
I think id rather remove the stock headlight/ number plate and install two of these. One for low, two for high. They have spot and flood so you could get one of each. http://www.ebay.com/itm/7-5-36W-LED-lig ... ae&vxp=mtr
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
jwhking1315
Post by jwhking1315 »
rsr02 wrote:I was thinking about the A/C thing and came up with this. A LED is basically a diode, meaning if the a/c power going into it is +-+-+-+-+- the led is only lighting up on the pluses. Meaning, I think, that the photo above is the light only running on 6v dc. Of course I could be completely wrong. Either way I am going to give the LED headlight a shot.
No. AC power is on a sine wave. If you are measuring 12V AC at the headlight, that is 12V RMS. RMS is average voltage that is measured by your meter. PEAK voltage in the sine wave is going to be around 16.97 volts. That means your voltage is going from 0 to +16.97 volts to 0 to -16.97 volts in one cycle.
Say your sine wave is going at 60 hertz. That means that your LED headlight is pulsing at 30 times PER SECOND due to the LED only using the positive pulses.
Peak to peak voltage is actually 33.95 volts. But the LED only uses half of the pulses.
Remember, this is all AFTER the voltage regulator. True stator output can be much higher
Roadhazardguy
Good info! I may have to ask you some questions when I get back to doing my 3 pole stator, you sound like the guy to ask.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
jwhking1315
Roadhazardguy wrote:Good info! I may have to ask you some questions when I get back to doing my 3 pole stator, you sound like the guy to ask.
I won't mind at all. I may not know the answers, but will help you out the best I can
sailorcolin
Post by sailorcolin »
flyboy wrote:Great job on this . If you do convert your bike to dc would you mind doing a write up on it?
Cheers
dont mind at all! i love electrical because most people are afraid of it but it really isnt that hard :)
zz3gmc
Post by zz3gmc »
Just ordered one to try on my KX500. Ive been looking for a halfway descent LED light that would run off of my 65w coil. The problem with the 500 is when Im riding in the woods at night the revs are so low that the light is dim.
Madmattymayhem
Post by Madmattymayhem »
Score! I already have those exact lights!
Has thanked: 8 times
Been thanked: 42 times
MADMATT, how is this LED light powered / wired on your bike?
