1983-1985 KDX200 piston kits
Kdxjoe
I know this is an old thread but dose anyone have a piston for a 1984 kdx200? They are impossible to fine and I'm really in need of one any help would be great thank u
- Has thanked: 159 times
- Been thanked: 39 times
Re: 1983-1985 KDX200 piston kits
Look in another thread for info on the Wossner piston.
yamada racing yz250
- Country: us
Hi what year piston kit did you end up using,I was thinking of an 86 kit,I cannot find any source anywhere for my 85 kdx200,I plan to do the same thing you did,just grind down ends alittle and should be good to go,thanksDe250r wrote:I just put a Wiseco in my 83 kdx200.i orderd a piston kit from a late model. Had to grind alittle on the bottom to clear. It had a Wiseco and I just ground down till it matched the original and then made sure it cleared the cases and its good to go.
Sent from the back woods of vt via patchy Internet
Live free and ride hard
You all need to read up on piston pin locations.
Look for Wossner.
Look for Wossner.
reddawg1322
- Country: united states
runningman do you still have some of these pistons available, if so what is your priceRunningman wrote: 10:37 am Mar 05 2012 I Have literally the only Piston kits on the planet for 1983-1985 KDX200!!! Piston, rings, pin and circlip. they are on Ebay!! I will have more made when these sell out. German made, kick A$$ quality!!!
"Last active:10:43 am Jan 01 2014"
Just buy a Wossner kit.
Correct. Get yourself a Wossner 8093DA piston kit and get that thing braaping. It’s what I use
a.natsis
- Country: Australia
Hi All,
Apologies, just playing catchups, so with that Wossner 8093DA, it can be used on a 1984 KDX200 ? Im looking at getting this model bike, its in great condition, but just seeing what options I have down the tack once its ready for a Tope End Rebuild. Thanks. Arty.
Look up a post from AUS member Geoff. He had pics.
a.natsis
The issue is the piston ring pin location on the Wiseco and later model OEM pistons. Snag a ring in a port, and it is a HUGE problem instantly.
