KDX220 won't run right
Griffbones
Post by Griffbones »
big gear head wrote:Nope, still trying to figure it out. I checked the kips valves and they are opening. I took the silencer off and it didn't help. I put the needle clip in the top groove and it ran a little better. It still won't idle no matter what I do. I took the air screw completely out and it didn't make any difference. I can screw the idle screw all the way in and all the way out and it makes no difference.
This kind of sounds like a plugged up carburetor if the air screw has no real effect.
And are you sure the float level is running correct?
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
kdxmaniac
Post by kdxmaniac »
does your carb have a o-ring on the float seat?
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
big gear head
Post by big gear head »
I have had the carb apart several times. I cleaned it with carb cleaner. I ran root canal files through all of the ports to be sure that they were not plugged, and I have checked all of the ports with air to be sure that they were open. I'm going to replace the jet block gasket and see if that helps. I checked the float and needle and they are good. I set the float level with the sight tube.
'98 KDX220
stomlinson
we got my buddies 220 running good
Post by stomlinson »
Gear head I hope this helps my buddys bike was doing the same thing as yours this is what we did..... We set his air fuel screw to about 1 and a quarter turns out, installed a 38 pilot jet, installed a 142 main jet, set the needle clip to the middle notch, and replaced the br9 with a br8 plug and his bike has run perfectly all weekend the other thing I was going to ask was, who did the top end work? Cause if u put your rings on upside down that causes low compression. There are numbers stamped on the rings they have to face upwards, also u should try going to a leaner fuel we run belray MC1 at 50:1 with high test fuel and the bikes run sharp on that!!![/i]
kdxmaniac
Post by kdxmaniac »
50:1 is RICHER {fuel wise} than 32:1............
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Has thanked: 9 times
Been thanked: 17 times
Not to mention, less oil is NEVER the answer. I think the op is on the right track with the jet block gasket. I have seen this issue several times now with the 35mm PWK.
big gear head
Thank you for all of the suggestions. I will try them as soon as I can. I think I'm going to start with the jet block gasket because if that is the problem then changing jets won't help. I'm pretty sure that I put the rings on with the numbers up.
'98 KDX220
big gear head
I think I'm getting somewhere. I think the jet block gasket has been the problem. I replaced it and it's running better. The idle screw is working somewhat, and the air screw is also working a little. The bike picks up RPMs a little better and smoother now. I think it still needs some tuning.
'98 KDX220
stomlinson
Did u try replacing your pilot jet yet with a 38? Once my friend jay did that. He was able to turn his idle screw out. He also dropped his main to a 142
big gear head
I didn't go that far with it. I had a 40 and I put that in. I need to get some more jets. The jets that I ordered were larger because I was expecting to have to go that way with it. I didn't expect to have to go smaller. I had a 40 that I ordered for my son's XR200R, so I put that in. So right now I have the 40 pj and a 145 mj with the stock needle on the top groove. I'll play with it some more when I get time. I've got to get the 427 in my '69 Camaro back together.
