Well, sorry its been a few days since an update, but the bike is ALMOST DONE!!! I've spent the last few days getting it all back together, and tomorrow is the big day. I just need to add trans fluid, and coolant. Then I'm going riding!
Here are some pics of the process, yesterday's are missing, but the bike is now complete with the exception of side panels once the rads are bled. Pics will come, don't worry!
This goes back a few days, but here we go!
Got the cases back together, as you'll see later that silicone gets peeled off.
Cases together, right side ready for all the goodies:
Impeller in, new gasket on:
Shift shaft in, star detent in, kickstarter installed, and main shaft gears installed and torqued. Outer clutch basket going on.
New plates in
[IMG::]
http://img89.imageshack.us/img89/2562/dsc05239.jpg[/img]
For some reason they gave me 6 springs?
Clutch complete and torqued down:
Side cover installed, clutch cover installed, water pump cover installed, and as I mentioned before the excess silicone was removed now that it was dry:
Stator installed, stock timing for now. Silicone applied where the harness enters the case as per the shop manual.
New output shaft collar and O rings
[IMG::]
http://img177.imageshack.us/img177/293/dsc05244e.jpg[/img]
Piston, with rings gapped. Don't worry, I cleaned it before I put it in!
Bottom end lubed up, new base gasket installed. I used Motorex fully synthetic premix.
Cylinder on, base nuts tightened, i gave everything a generous coat of oil.
Head gasket on, and head tightened. It was upside down for this pic, I flipped it around before installing the head.
KIPS shaft showing proper alignment:
The FINAL piece!
The completed engine, showing my approval!
[IMG::]
http://img197.imageshack.us/img197/2852/dsc05253g.jpg[/img]
Next, I installed the engine into the bike, installed the sprocket, and torqued all the engine mounting bolts and headstays:
Installed the chain, tightened it as per the shop manual. Old chain was on #8 to be of sufficient tightness! Torqued axle nuts, installed new cotter pin:
Installed shifter, rear brake, rads, hoses, frame guards, airbox, fender, etc.
[IMG::]
http://img20.imageshack.us/img20/7399/dsc05263n.jpg[/img]
I didn't take any pics of yesterday's progress, suffice it to say that the bike is now finished. I installed my hour meter, temp stickers, carb, seat, number plates, etc etc etc... After one more check over, I'll fill the juices and give her the first kick tomorrow! Don't worry, pics and videos are forthcoming!
