I wanted to try it....but ski wouldn't let me near it.........
It's the funniest sounding thing! At the bottom of one climb (Screwed by a Tree...which screwed me...again), Wibby went first. I heard the normal RRrrr-RRrrr-RRrrr of a throttle controlled ascent. Then ski took off.
Ha! It was a constant RRRRRRRRRRRRRRR that didn't change except in volume when he went around a corner. Sounded like a leaf-blower or something.
He sure found some conditions that it flat don't work! If you need an 'average' amount of clutch control, it's fine. But, when you need a LOT..steep uphill, wet clay base..nothing beats the feedback loop between your left hand and your brain. When there is a hair trigger difference between traction and spin, the autoclutch is
too unforgiving..resulting in either too much force or not enough.
Good grief...if I would've had to put as much effort into going up a hill as ski did, I would've quit LONG before he did!!
Come to think of it....I
DID!
Another thing it's not going to do: Bulldogging your bike
downhill. Steep enough that braking a few inches of travel gets the back wheel off the ground, so you have your arm slung over the seat to keep it down. The bike needs to be IN gear...and NOT RUNNING to get you a BIT of tracking control with the back wheel under compression.
No compression in that circumstance with an autoclutch.
I was in neutral (a mistake I couldn't reach to fix), my back wheel as free as it would be with an autoclutch. It didn't work for diddle. I crashed.
Of course..if you bump it hard enough to
start in that situation...you are screw-ed!
