Project KDX 220R - The Rebuild
- Been thanked: 18 times
MadMax
Thanks. I have a set of the KLX forks and the springs are softer than the rear so I was trying to get some balance. I'm running the stock spring in the back and wasn't sure to trust Jeff Fredette's spring recommendations since he was talking about the KDX forks. So with all that said, does that rate give you good balance or do you wish you'd went stiffer?
MadMax
Jedi Master Team 5150
MadMax
Looks awesome Nick.
I have a couple more questions and I'll leave you alone. (If I could PM you I would)
Are you running the stock rear spring? If yes, is the balance where you want it with the .46 forks? If no, what rate did you go with. I'm roughly same size as you and I don't mind learning from your experience.
Thanks again!
Stephen
Thanks again!
Stephen
MadMax
MadMax
- ss109
- Has thanked: 32 times
- Been thanked: 50 times
Nick, what size holes did you drill in your clutch basket? I'm thinking this might be a good idea for using with the Dyna-Ring.
aebbern
Nick - you and I ride in the same general area (Calgary)... just curious what main and pilot jet you landed on after the RB work to your carb? Did you end up making any changes to the jetting after Ron rejetted it?
Cheers,
Andy
Cheers,
Andy
'07 Husqvarna TE610
'01 Kawasaki KDX220R
'79 Laverda 1200
'79 Laverda 1200
I did, but I think I only went down on the pilot. I believe I ended up with a 38 pilot and a 142 main. Bike is jetted PERFECTLY.
aebbern
Thanks - mine is currently running a 40 pilot and 150 main. It seemed a little fat on my last ride, will try going one size leaner.Slick_Nick wrote:I believe I ended up with a 38 pilot and a 142 main. Bike is jetted PERFECTLY.
'07 Husqvarna TE610
'79 Laverda 1200
'79 Laverda 1200
- Postigo
Re: Project KDX 220R - The Rebuild
nice bike and great post... very helpful during my rebuild project, thanks
GKBO
Helped with my rebuild to.Was going to try to blast the frame with ground walnut shells,till I read this.Got some ground glass at Princess.Got a blasting hood to,on sale for $8
86 KDX200 thread http://kdxrider.net/forums/viewtopic.php?f=119&t=13295
My other bikes:
85GS750EF,Old Yeller http://www.thegsresources.com/_forum/sh ... p?t=161477 and http://www.thegsresources.com/_forum/sh ... p?t=175660
78 GS1000 Red Skunk http://www.thegsresources.com/_forum/sh ... p?t=176156
Street bike rider playing in the dirt.
My other bikes:
bushx
Old initial thread, but a good one. I'm in Calgary too, and picked up an '01 KDX220 for the summer. Where did you pick up the case splitting tool? Interested in renting it? :-)
