My thread (2000 KDX 200 rebuild)
- Coop
Ultra copper will seal the head, my old 125 had pitting and it never leaked with the UC. The helicoils aren't that big of a deal, except the part about him missing a few damaged threads and you have to coil them yourself. Given that it's not even your original cylinder, well that's BS in my opinion! I was planning to send mine to him this winter because of my past experiences talking with him when I was an active member years ago on dirt"rider".net forum and he posted tech stuff there. I will NOT be doing that now
"Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain
2003 KDX200
2003 KDX200
bmiller
I completely agree with the BS on having to helicoil a few myself. However, to his credit, the machine work looks beautiful.
I didn't mean to bad-mouth him, he has a great reputation. I just got the feeling that a top-end to him is like us filling our bikes with gas... it's childs play and is easily accomplished. He focuses his talent on the machine work.
I'll post more pictures of before and after I fixed the cylinder (more helicoils, cleaning, paint and installation).
I had a cylinder done by LASleeve a few years ago... never again.. their machine work is horrible.
I would absolutely use Eric again,.. I would just be VERY clear on what I'm looking for. Maybe even write it down before I call.
KarlP
I don't know about all that, sounds fishy.
I've never heard great reports about the 225 job. Seems like trying to make the KDX motor something it isn't.
Do take a close look at the bore the KIPS actuating rod runs in for the RH subport valve. That rod has an o-ring seal on it. The plating/pickling process gets that bore very rough and you'll end up with sticky KIPS valve operation. Emory cloth on the right size drill bit will fix it, but you better check before you put the cylinder on 'cause you can't do it on the bike.
'08 KTM200xc
KX100 for the boy
KX100 for the boy
- Coop
I didn't think you were bad mouthing him. I am just less than impressed with your experience. I was thinking more along the lines of cylinder porting and the RB carb and head mods vs a "big bore" anyway, so I need to research my options there.bmiller wrote:I completely agree with the BS on having to helicoil a few myself. However, to his credit, the machine work looks beautiful.
- ihatefalling
- Griffbones
Hate to say it but this is typical Eric Gore!
Do a little reading on the web, he is renown for pulling this crap.
That guy had one of my engines for over three months, then when he finally got around to sending it back to me, it wasn't even my engine!
I had a real time with this guy, he is a real bone head IMHO.
I will never, I repeat never, give Eric Gore any work or recommend him to anyone ever again!
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
bmiller
Wow,.. I've only read good things so far. Who do you use for machine work now?Griffbones wrote:Hate to say it but this is typical Eric Gore!
That jack ass had one of my engines for over three months, then when he finally got around to sending it back to me, it wasn't even my engine!
- Griffbones
For cylinder plating US Chrome, machine work a local guy. All other things I do myself.
US Chrome used to do all of Eric's plating and they even rented him some shop space to work out of, until he pissed them off too. Now he has moved onto Power Seal as his plating company. Eric has bad mouthed Max Power/RPM, but he actually worked for Max Power when they first started their plating business in the USA several years ago. That was prior to Rick Peterson Racing merging with Max Power.
Eric is a very good tuner, just a poor business man.
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
bmiller
Excellent information and history... thanks.Griffbones wrote:For cylinder plating US Chrome, machine work a local guy. All other things I do myself.
US Chrome use to do all of Eric's plating and they even rented him some shop space to work out of, until he pissed them off too. Now he has moved onto Power seal. Eric bad mouths Max Power/RPM, but he actually worked for Max Power when they first started their plating business in the USA several years ago. That was prior to Rick Peterson Racing merging with Max Power.
Eric is a good tuner, just a poor business man.
bmiller
bmiller
Reassembly begins!
http://www.phospher.com/index.php/2000_KDX_200
Do those bar clamps look correct? Also, what is the little alan set screw on the side of the axel for?
- ihatefalling
- Coop
