Different Rear Spring
thedeatons
Hey guys... I did a "rear spring" search, but couldn't find what I needed. I weigh 155 with street clothes on, so I am looking for XR400 springs and a different rear spring. I think I have found XR400 rear springs, which will help the front.
Question: Where are you guys getting different rear springs? FRPOffroad says I need a 4.8kg spring. Any recommendations?
Anyone have one for sale or happen to know which manufacturer to buy a new one from?
Thanks!
James
Thanks!
James
thedeatons
The rear spring you have on it stock is good to 180#.... you may need to rebuild it though.
thedeatons
thedeatons
Just ordered some stuff from FRP today. Talked to Jeff and he was very helpful.
Gold Valves with shims set for my weight and riding style for the forks
OEM Kawasaki Fork Seals and Dust Seals
Race Tech rear spring for my weight
I also picked up a half price rear shock Gold Valve kit on Ebay, and have '96-99 XR400 fork springs on the way from another site (FREEBIE!)
Red Line Extra Lite oil will go in the rear shock
Red Line 7.5wt. oil will go in the forks (mix of 10wt. and 5wt.)
Should be an interesting difference. I may wait until winter to do it though. Not sure I want the down time during the summer....
James
James
thedeatons
Just got all the remaining rear shock parts in today and should be sending it off to my shock guy soon. He is rebuilding the shock for $30 (changing fluid, installing Gold Valve with Race Tech's custom shim stack settings, recharging nitrogen).
Should have some input on it soon. Still waiting on the XR400 fork springs.....
James
James
Good DEAL!
thedeatons
This guy from the XR forum just called me. 1999 XR400 fork springs are in the mail for $30!
I also just ordered every bearing and seal needed for the front hub, rear hub, swingarm, and linkage through CheapCycleParts.com. $214 shipped for everything. They were $35 cheaper than Ron Ayers!
I ordered the double-sealed lower shock bearing from McMaster-Carr as suggested by another forum member....
Looks like I have some work ahead of me.
James
James
