Wet Air Screw
Tomm9050
Post by Tomm9050 »
Does the stock silencer have fiberglass packing? Can't tell from the diagram.
1992 KDX 200; RB head; Fatty pipe; stock carb; Stock silencer
40 / 150 / CGK pos 3
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yours is a 92 right? I think it does....
Tomm9050
Post by Tomm9050 »
Yes 92 stock silencer.
there's really a lot of goo coming out the pipe.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Change your packing.... I bet it is just a gooey mess....
Tomm9050
Post by Tomm9050 »
OK, what's the trick to disassembling the stock silencer?
I removed all the bolts, the end cap won't come out.
Any suggestions?
Thanks
Tomm9050
Post by Tomm9050 »
the trick is to gently tap on the exhaust tip pushing it into the body so that you can pry the end cap out.
any suggestions for replacing the the fiberglass donut? will reg fiberglass muffler packing work?
Tomm9050
Post by Tomm9050 »
There seems to be some sort of glue or caulking around the edge on the end caps of the silencer. Any suggestion on what to use to replace them / if nec.
fuzzy
Post by fuzzy »
Hi-Temp RTV.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Tomm9050
Post by Tomm9050 »
What's RTV?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It's what's on the rack at your local Auto Parts store.....
fuzzy
Post by fuzzy »
Yep. Simply put it's hi-tech silicone caulk. :mrgreen:
http://www.permatex.com/products/Automo ... _Maker.htm
Tomm9050
Post by Tomm9050 »
Got it, worked great.
Tomm9050
Post by Tomm9050 »
air screw adjustment? turning it OUT is rich or lean?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
lean....
scheckaet
Post by scheckaet »
letting more air in, so less gas, so lean. Is that right?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yep!
Tomm9050
Post by Tomm9050 »
Finally, got the silence cleaned up and reinstalled, raised the needle (1173) to the 4 clip (it was bogging) and it seems to run much better! Thanks all.
