What has anyone found that works good for proper jetting a 200 and a 220 at 700 Ft. ? Airbox top 3/4's removed and FMF pipe , Frederette torque ring and aftermarket silencer.
Idle air screw-
Low speed Jet-
Main Jet -
Needle position-
Rough Jettings numbers vs. stock
Air temp? Winter air requires fatter jetting.... a 155 main and a 45 or 48 pilot should work on the 200... and clip in the middle for the needle.
Curious George
There is no "stock" jetting from what I can tell. It depends on the dealer and what they put on when they prep the bike. I assume they get a jet pak and use that.
Curious George
KarlP
"A 2005 220 with 33mm carb , Pilot jet #42 , Main jet #145"
That is how my '02 220 came stock.
I think I ended up 140/38 with a shiny pipe and 1/2 the airbox lid cut out.
You'll have to work on your own jetting; mine is specific to my bike, location, temp and riding style and NOT a recommendation as to what you should run
I'm not being a butt. The stock settings will run the bike, a couple of hours of carefull jetting and air screw changes will get it running nice and crisp
'08 KTM200xc
KX100 for the boy
KX100 for the boy
When Inda said 'There is no 'stock' jetting...' I believe he was referring to jetting a stock bike to a definite jet-set, NOT what 'comes with'.
The 200/220 numbers you posted are good for all 'H' model 200s and all 'A' model 220s (as far as I know, no warranties expressed or implied).
Certainly (as Inda said) a KDX could have rolled out the showroom floor with something different from OEM due to dealer changes.
- Mr. Wibbens
Re: Rough Jettings numbers vs. stock
A lot of this info might be found in the " Members Bike Profiles" section on this siteCurious George wrote:What has anyone found that works good for proper jetting a 200 and a 220 at 700 Ft. ? Airbox top 3/4's removed and FMF pipe , Frederette torque ring and aftermarket silencer.
Idle air screw-
Low speed Jet-
Main Jet -
Needle position-
