Fork Swap Recommendation for Short Folks
Has thanked: 39 times
Been thanked: 102 times
Re: Fork Swap Recommendation for Short Folks
HeyItRuns,
your black spacer placement is similar to the black plastic spacer I installed in my 1999 KDX 220 forks. Also, there is a metal OEM spacer in my forks. My photos show before & after I put the black spacer on the rod. You can see where a spring is on mine.
Has thanked: 181 times
Been thanked: 46 times
Wrap some plumber tape on the threads before you put the rod back through the seal / bushing.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Update:
I reassembled the forks. I bought the wrong springs from RaceTech, so they just came in. I am working on the shock for now.
I'm rebuilding the rear shock and I'm going to lower it internally using the race tech spacers as mentioned by Chuck78 above. I used the guide from RaceTech (see link below) and measured the distance from fully extended to the length extended when I raised the wheel 1". It looks like it's about a 5-6mm difference.
https://racetech.com/ip-spls-lowering-spacer/
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Update:
New springs from RaceTech came in. I installed them and used the included spacers to set the preload. It took me longer than I like to admit to decipher how to place the spacers using the surprisingly bad instruction sheet that came with the forks (see link on previous page).
Basically, I just needed to add spacers until the springs touched the fork caps (which makes free length = set length) and then measure out the number of spacers equivalent to the desired amount of preload (4mm according to their website). This ended up being a total of 5 spacers. For anyone reading this in the future, the spacers go at the bottom of the spring because if they don't, you can't attach the fork cap.
I then set to work on the shock. I used these two videos:
The first is kind of a general overview, but is really well edited.
The second has worse camera angles, but is specific to the kdx. It was good for some things but not others. More on that in a minute.
I was able to get just about everything apart. It was incredibly dirty and things were stuck that had no reason to be. The top video kind of shows how to disassemble the shock, but shows a different KYB shock with a different retaining ring. Ours use 2 overlapping rings that fit in one another. Mine were rust welded together and I had to hit em with a hammer a little. The cap that goes over the bladder was also a pain. I ended up putting a socket over the schraeder valve and using an even bigger hammer. I was able to pull the cap out with this tool, which I recommend.
https://www.amazon.com/s?k=atv+shock+tool
Then things started going sideways. I ran into 2 issues:
1) I didn't have everything I needed. I bought the parts to do this a while ago, and I thought I'd bought a kit. I didn't. I bought a seal head and bladder from All Balls. I realized after reading other threads here that I still need a new nut, piston ring, and piston o-ring. I bought them from ebay and they are on their way.
2) I also made the mistake of following the instructions of the second video step-by-step, and in the video he mentions that he did not remove the peening from the top of the piston rod and just chased the threads. This was a terrible idea. I put it in a vice and just used a big wrench to crank on it. I did in fact get the nut off, but it took with it the top 2 1/2 threads, which were left half attached at a jaunty angle. I had to grind off those bits as carefully as I could. The link below is a post from this site that has really good instructions on how to do this the right way if someone wants to see that.
viewtopic.php?t=25898#p224264
This is a Facebook post that has really good pictures of the process.
This is a picture of my piston ring. Note that it is in fact cooked.
This is a picture of poor piston shaft. Note the marring at the top from where I had to grind it.
Questions:
1) I have a snap ring that came with the new seal head, but I don't have a new one for the bladder. Do I need a new one, and if so, where can I find one? I've been looking at the diagram, but there is no part number.
2) Does that piston rod seem saveable, or should I just call it and try to scrounge up a new shock?
3) Does the nut really need to be a KYB one?
Thanks for the help in advance.
OUCH!! I did that the first time I worked on one, but that was before Youtube and forums.
I would try to find a thinner bottom plate / washer. That would move the nut down. A KYB nut has the metal portion to catch the threads. 25 foot-pounds of torque and red Loctite.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Got a little bit done last week.
I managed to remove the old piston ring. I'm including a picture of it below in case anyone wants to see what a really worn one looks like.
I knew it was in need of replacement, so I just broke it in half using a pick rather than trying to save it. I bought a new one and a new o-ring and put the piston in the freezer for later. I'm going to try the technique noted here:
I also did my best to save the threads on my piston rod. I used a two-piece dye I bought off of Amazon and some cutting oil and was able to make surprisingly good progress in that regard. The two pieces of the dye fit around the undamaged threads and by working it off of the rod, I was able to salvage most of the damaged parts. Here are the pictures of the progress.
As you can see, the top threads aren't perfect, and when I thread my new nut on, it still feels similar to cross threading until that portion is cleared. The new nut is not a KYB spec replacement, and it's a little shorter than the original, but I'm hoping it will hold on with enough red locktite.
I still am trying to find the snap ring that holds the bladder cap in place. I've been searching high and low, but the diagram doesn't have a part number. I might just reuse the old one if I can't find it. This is the one I mean:
If anyone knows where I can source one, I'd appreciate the input. I've been looking at Technical Touch's website, but I'm having trouble deciphering it. I am planning on keeping the stock spring. RaceTech's website doesn't provide a replacement recommendation when I use their lookup tool. I think for the moment it will be fine for the light commuting and adventure riding I'm planning.
Sorry for the long post folks and thanks in advance.
HA HA. I did finally find someone who cut one of my mounting tools down.
The nut will be fine. 25 foot-pounds.
I would just reuse the clip.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
KDXGarage wrote: 11:23 pm Apr 02 2026 HA HA. I did finally find someone who cut one of my mounting tools down.
Awesome! I've got the piston in the freezer and I'm going to try putting the band in hot water and sliding it on with some fork oil and a feeler gauge.
Thanks for the reassurance on the nut and clip. Nice knowing I'm not losing it.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Because I had some down time I bought a 2022 klx300 spring with 8hrs on it for $38 on eBay. I know the old klx300 springs fit and were a cheap way to get a higher spring rate. It looks like the new ones use the same kyb 44mm shock. I'm not sure if the length is the same. Spring rate is 5.6kg/mm.
I'm 185lbs without gear and the bike is a couple pounds heavier than stock due to the battery, skid plate, bigger radiators, fan, etc. It might be too much spring, but seemed like it was probably better than what I started with.
I think a 5.2 would be good for you.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
KDXGarage wrote: 11:34 am Apr 03 2026 I think a 5.2 would be good for you.
Good to know. I'll bear that in mind for when I buy the correct spring.
This was just meant to be a temporary fix, and I was honestly curious to see if it would fit.
The forks are running .50kg springs, which was what RaceTech recommended, but also seems stiff. This might be because when I was using the tool I set it for "dual sport" use rather than "enduro" or "mx". We'll see how it goes.
I don't think you are way off on the fork springs. 46 may have been about right with the extra stuff. Try to compensate with the compression adjuster some.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Update:
Made some progress this afternoon.
I left the piston in the freezer and put the band in boiling water for a few minutes. I dunked them both in fork oil and was able to slide it on with my thumbs. It took a few tries but I got it. I finished it off by wrapping the whole thing in electrical tape, adhesive side out and throwing it in the freezer.
I tried using the goofy tusk piston bullet thing to protect the new seal, and it fit over the threads, but the seal head didn't fit over it. I don't recommend it.
I tried using electrical tape, but that didn't work either, so I gave up and just slid it over and prayed. Seems fine. I measured 6mm of the RaceTech spacers and stacked em on top as specified by the instructions.
I put the valve stack and the piston back on. It was kinda tough getting it over all the janky threads, but I managed with a little effort. 25 ft/lbs and red locktite.
I got the bladder on, but I wasn't able to get any more progress done because I was waiting on a replacement bleeder screw, which came later in the evening.
I also went to go put on the tires, but I saw the beadlock and thought better of it. They're at CycleGear getting put on by someone more qualified than me
Good job!
Was the seal bullet for a 16 mm shaft?
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
KDXGarage wrote: 05:17 am Apr 07 2026 Good job!
I used this one:
https://a.co/d/04211fBK
This is an excellent example of lazy googling. When I was looking for the bullet I googled "KDX Shock Rod" and this popped up.
However, upon clicking on the post, it turns out that it is a different user who has a shock that is not original to the bike. And even more damning...
So, I recant my previous statement. The bullet is probably great for it's intended purpose, but not for bikes with a 14mm shaft diameter, like our bikes.
Yeah, it looked just barely to big over the shaft. KDX 1986+ USA models have a 14 mm shaft.
I think KX went to 16 mm in the mid to late 80's. A few Suzukis and YZ's have (or had) an 18 mm shaft.
A lot of electrical tape wrapping would allow the seal head to slide by.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
Update:
Installed the new bleeder screw. Which is a nice improvement from the previous one and followed the rest of the instructions on the video to clean the shock body and reservoir.
Filled the reservoir with oil, installed the bladder, filled the cylinder with oil, and went to install the piston. I got stuck for a bit because the piston band wouldn't fit into the cylinder and got deformed just around the edges. I tried rewrapping it in tape, which didn't work, then in tape with a hose clamp, then freezing it. No luck. I ended up getting it to work after a friend of mine suggested I shave of the offering little edges with a razor. It's not perfect, but it covers the o ring and it's pretty close.
I finished reassembly and then tried putting a little air into to bladder to see if it would hold air before I took it to the shop, and it kept leaking. I took it apart like 5 times, changed the snap ring, changed the bladder back to the original, which helped, and then ended up figuring out it was the schraeder valve of all things. Swapped that out and she holds air. Got it filled at a local shop.
My spring came in and seemed to be the right size. I took a picture for comparison.
You will note that at the bottom it is tapered. That's because the spring on the klx300 does not use the spring guide the kdx uses (part no 13070 in the diagram). Instead of just uses the other ring (13070A). The part number is the same and it works perfectly once I omitted the ring, but it took me a long time to figure that out.
I slapped on some cheap NiceCNC lock rings I got off eBay for $20 and reassembled and mounted it on the bike.
I don't have any pictures, but I also managed to get the steering stem bearing and race out, install the new ones, and my forks. At first, I was a little disconcerted because it seems like the forks were not as short as I expected, but I was able to remedy that by sliding the forks up in the clamps a little. I still haven't tried to set the sag, but that's next on the agenda.
Looking good! Keep up the nice work.
HeyItRuns
Has thanked: 1 time
Post by HeyItRuns »
The bike is all back together, and I can in fact touch the ground.
It took me a while to get everything assembled. I had taken the airbox apart to get to the shock and I needed to reassemble that, mount the brake line, and do some other work to the bike along the way. I also decided to piece together a Scott's Stabilizer setup using an old Scott's triple tree upper from a 2000 kx125 and a beat up stabilizer I got for cheap on eBay. I bought some used 1 1/8 bars to complete it. So I was waiting for those to arrive for a bit.
The change to the new triple means that I can't use my old handguards and I'm going to need to get creative with mounting the headlight. At the moment it is held on with zip ties. I'm gonna rebuild the stabilizer and weld on the new post for it I got off brp. It looks like it may take some editing to get it to the right length and it's going to be a little tight with the gas tank, but it's going to be a nice combo.
That might be for another post at another time.
Thanks for all the help guys!
