Supermoto conversion
Hamkdx200
Country: Australia
Post by Hamkdx200 »
Hey guys I just picked up a 2000 kdx 200h it’s an absolute dream I get why everyone loves them but I would like to put some supermotard wheels on it but I cannot for the life of me find what will work. I want to have 2 sets of wheels one for road one for enduro but the oem hubs are nla and expensive so I thought someone here can help because nowhere does it say what will work and what won’t. I found an American website that has them but they don’t ship to Australia I just want a pair of 17 in wheels for it and I’d rather not spend 5000 on it as well. I’m thinking I buy an old set of kdx wheels and strip them down and get the hubs re spoked and rimmed which may be the cheapest option but does anyone else have anything else that will work. I work at a Kawasaki dealer so I can get pretty much everything, like even if wr or another brands wheels will work just anything please.
Someone please help 😭😭
SpruceItUp
Has thanked: 123 times
Been thanked: 42 times
Re: Supermoto conversion
Post by SpruceItUp »
There might be some older KX's that might have wheels that work. I'm unsure. I'd lace the hubs onto new wheels if it was me.
I do have a a question though, since you're turning it into a supermotard, are you upgrading the forks? I couldn't imagine the stock suspension would be very good for riding like that.
My 04 CRF450R has a set of Warp 9 supermoto wheels on it and the suspension for it is great, but it's the complete opposite of the suspension on my KDX. It's very stiff.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Pretty much your only option is to lace new rims to a set of kdx or kx hubs, there are a few folks on here who have done it. IIRC about the biggest you can go on the rear is a 4" rim before you get into serious chain rub and alignment issues, you'd probably still have to dish them with some offset to help as well in the rear. Search the forums and you should be able to find what you need.
JimmyB
Been thanked: 12 times
Post by JimmyB »
You might get lucky with the 17" wheel assemblies from the Supermoto KLX300SM, check over the parts breakdowns. If you have one of them at work possibly check the width of the hubs(possiblity if Offset also) and collars(spacers) on the forks and inside width of the swingarm. The rears use the same bearings(6004) so axle diameter would be the same but unsure about length. Some custom shims might have to be made for centering and for retaining clips, possibly custom for the collars also or a mix, for example on the front the KDX uses a 12mm wide collar the KLX 14mm wide opposite the odo drive but again they are both different id, the rear the KLX uses a 20mm wide and a 22mm wide collar the KDX they are both 22mm wide.
My friend had a KLX300SM stripped down for only track use and I had looked into it for my KDX late last year just for fun but before I could test fit off his bike he sold it in the spring, I have a 04 KLX300 front end on my bike so it might have just been bolt on?
02 KDX220
Hamkdx200
Country: Australia
Post by Hamkdx200 »
SpruceItUp wrote: 08:59 am Sep 16 2025 There might be some older KX's that might have wheels that work. I'm unsure. I'd lace the hubs onto new wheels if it was me.
Hamkdx200
Country: Australia
Post by Hamkdx200 »
Yeah I might have to do that find some old hubs that are the same or similar but I already have a set of kx 250 forks from an 02 model on it which pretty much went straight on that was the first thing I had to do cuz I was using all the travel on those oem shocks cuz I’m about 100kg and 6’6 so if I wanted to do any serious riding I had to upgrade them
Thanks for the help
Has thanked: 239 times
Been thanked: 119 times
Hamkdx200 wrote: 04:01 am Oct 06 2025
Yeah I might have to find some old hubs that are the same or similar, but I already have a set of KX 250 forks from an 02 model on it which pretty much went straight on that was the first thing I had to do cuz I was using all the travel on those oem shocks cuz I’m about 100kg and 6’6 so if I wanted to do any serious riding I had to upgrade them
If you have '02 KX250 forks on it, are you planning to also run those when you would switch it to Supermoto wheels?
If so, you'll be needing to look for a '99-'02 KX125/250 front hub, and not KDX/KLX front hub. The same years of KX rear hub (really all the way back to 1990) will also work although some years may require some different spacers. The KDX rear hub will be the most straightforward swap, or a KLX rear hub with KDX spacers, but KX 1990-2002 rear opens up more search options. 1997-2002 KX have a 3rd wheel bearing in the rear, on the drive side, for added longevity and durability. The 1993-1998 KX front axles and spacers definitely will NOT work on those forks, however - stick to 1999-2002 KX axle and spacers.
Around 1993 or so was when the front axles jumped up from 17mm to 20mm diameter, so you'll have to search for front hubs after that model year. You may want to verify the exact year but I'm certain 1994 was the 20 mm, 1993 may have been the first year for it. The best bet is to go with the 99-02 KX front wheel although the hub may be the same spacing (& required spacers through '05/'06, but I do recall those later hubs use different length spokes due to a different flange offset).
