1991 KDX 200 Rebuild
Chadnutz
I purchased a 1991 KDX 200 about 3 months ago now. Fixed the clutch issue it had, then went for a 30 minute ride. I noticed an oil drip immediately after putting the bike back in the shop. The oil filler read empty, which scared me. I decided to remove the engine from the bike and plan on getting new seals and bearings. Does anyone have any recommendations or places i can search for parts?
- Has thanked: 181 times
- Been thanked: 46 times
Re: 1991 KDX 200 Rebuild
Welcome to kdxrider.net.
When reading the sight glass, did you have the bike straight up and down or on the kickstand?
Chadnutz
Straight up and down. plus, when i kicked the bike, the level would rise and fall
Do you have the transmission vent hose?
Is it leaking oil externally?
How long did you wait to check the oil level after the engine was running?
Chadnutz
OK, the reason I ask is because it takes a while for it to all settle back down.
Chadnutz
- Been thanked: 10 times
Where was the oil leaking from? I ask because the location of the leak will determine whether a seal kit is going to solve it or not.
