Water pump cover gasket installation
jrklark
Post by jrklark »
Hi all, newbie question :grin:
I had to replace the water pump seals on my 1992 KDX200. Should I use RTV on the water pump cover gasket?
Thanks!!
jrklark
Re: Water pump cover gasket installation
No, if all your mating surfaces are good then just the paper gasket and proper torque are all that are needed to seal it up.
Has thanked: 184 times
No goop, just the paper gasket. Torque to specs in manual.
jrklark
Post by jrklark »
Thanks!!
You're welcome. Welcome to kdxrider.net.
Been thanked: 53 times
Yep, no sealer. However, I do use a little smearing of grease on both sides of the gasket to facilitate removal down the road.
