KX clutch/brake lever on stock perch?
0ryxr5
- Country: South Africa
Hey, I recently took a fall and bent my brake lever, the ball end on my clutch lever is also gone, I tried bending my brake back and it snapped
I don't live in the US or Europe so Ebay isn't an option unless I want to pay a pretty penny on Import taxes, my easiest option would be to look for KX levers because they are much more common, so would KX levers work on a stock perch? Thanks in advance
- Been thanked: 10 times
Re: KX clutch/brake lever on stock perch?
P/N 46092-1186 For front brake 93-96 KX125/250, 97-2007 KLX300, 93-96 KLX250
P/N 46092-0045 for clutch 85-89 KX125/250, 95-97 KX100, 97-2007 KLR300 and a couple of odds and ends
- ss109
- Has thanked: 30 times
- Been thanked: 45 times
Or replace the complete perch and lever from a KX on to your KDX.
Yes clutch lever with perch is basically universal for 7/8 bars. Brake is a little more challenging, but if you replace the perch/master cylinder as a unit not so bad.
