I got the parts to street legal the KDX but I'm having trouble right off! The K&S hydraulic brake light switch is too tall for the rear reservoir. Any ideas?
I also got a magneto puller, Electrex 65W coil, and a 35/36.5 W halogen bulb to repace the stock bulb. Am I likely to run into any other problems and is the halogen bulb going to generate too much heat for the stock headlight?
Brake Light Switch
OverTheHill
OK... here's how you do it. Put a couple of washers behind the cylinder mount, this will set it out far enough to clear the switch. I also had to bend the guard out slightly for piece of mind.... but it is pretty easy to do....
- quailchaser
Yep Indy's idea works well. I got a longer rubber brake hose and made a bracket that moved the resevoir up. I also, had to modify the guard slightly. Good luck.
Later
Robb
Later
Robb
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
