Thanks
Kips governor shaft
Garydll
Kips governor shaft
Thanks
- Been thanked: 10 times
Re: Kips governor shaft
yes. I assume you are referencing part # 13234-1101. If so, is part # 13236-1260 still attached and intact. When you disassembled the motor you did remember that the pawl on top of that shaft is held on by a left hand threaded nut, not a normal right hand?
Garydll
I don’t do this everyday. I did this once before and didn’t have any problems. I started off maybe a bit to confident trying to get R done.
This all started with my transmission output shaft and sprocket suddenly stripped out while having it pegged in 2nd smoothing out the rock and bumps on the trail. My gears seemed to be jammed at that time. The next morning all my oil is on the floor. The shifter shaft seal was bent.The output & shifter shafts, seals were first on the list , began teardown.
The bikes all apart , All gears perfect. The forks, drum, everything looks good.I have my 2nd batch of kips parts soaking. I’m still waiting for some after thought parts.
I cleaned my cases, bla bla bla. I’m playing around making sure I could put it all back together, got my hands on the kips governor shaft. The shaft on the inside of the case is straight, all looks good but the shaft after the case going to the gear seems a little bent.
Would someone stop me from ordering more parts and loosing more of the few days left this year. Give it a tweak a bit if needed ? Wait for more parts?
I think I know ?
Garydll
- Has thanked: 116 times
- Been thanked: 31 times
OOps. We live and learn.
