paint code, KDX PIPE
deepwoods
- Country: Norway
hi guys, does anyone know the paint code on the pipe for the cirka 98,99 and up kdx 200/220? . its gray and very durable.
KDX 200, 2001 model
deepwoods
- Country: Norway
- Has thanked: 160 times
- Been thanked: 39 times
Re: paint code, KDX PIPE
Hello. I don't know.
deepwoods
- Country: Norway
no problem, do know if there is a write up anywhere on this forum on the subject?
KDX 200, 2001 model
- KDXohio
Do you have a paint store local that can mix up something?
deepwoods
- Country: Norway
thanks guys but colorite dont have for the pipe, only green paint, yes I have store somewhat close but haven't asked them yet,
KDX 200, 2001 model
- KDXohio
Whoops sorry I didn't notice you were looking for the pipe color
Colorrite has other colors if you search around, but there is no "paint code" given by Kawasaki for a KDX pipe. If someone ever matched it up, then whoever you see in Norway uses the same system at a paint shop, then you night have a miracle. Otherwise, you are going to have to brick and mortar it.
deepwoods
- Country: Norway
thanks anyways guys, I just hate the chrome look off the fmf and since the stock pipe coating is very tough I wanted the gnarly to look the same way
KDX 200, 2001 model
pumpguy
- Been thanked: 2 times
Looking at both of the pipes I have, I don't think these are finished with a paint, as such. To me, it looks like something better; an industrial heat resistant coating of some sort.
Most folks seem to refinish their pipes with a heat resistant flat or gloss black.
Please let us know how you make out on this, especially color match and long term results. I'd really like to know.
- KDXohio
I repaint my pipes with a ceramic engine enamel. It holds up very well and has a pretty good finish vs like a heat resistant barbecue paint.pumpguy wrote:Looking at both of the pipes I have, I don't think these are finished with a paint, as such. To me, it looks like something better; an industrial heat resistant coating of some sort.
pumpguy
Thanks for this information. I'll keep it in mind for next time.
Is this ceramic engine enamel easy to find? Is there a color that matches the sort of brownish stock pipe color?
