Stock H series 200 Carb ID
slidinleft
Post by slidinleft »
When I measure my 95 carb inside diameter measures 36.2 mm.
Can someone verify what their stock one measures.
Trying to figure out if its stock or not.
Airbox side looks polished .
Thanks Sean
Has thanked: 160 times
Been thanked: 40 times
Re: Stock H series 200 Carb ID
You might find dimension on the Keihin site or Sudco, maybe jetsrus.
Where are you measuring the ID at? It should be measured at the slide (narrowest part of the carb throat, not at the end where the carb mounts to the boot). The PWK33 and 35 both share the same outside dimensions, which you can find on Sudco or JtsRUs or a google search
