95 kdx 200
jimmy97
95 kdx 200
Post by jimmy97 »
does this look right to anybody? this is at tdc .Image
Sent from my VS985 4G using Tapatalk
95 kdx 200
I assume your asking about the piston to deck difference? It looks deeper in the hole than I have seen. Does it have two base gaskets on there or an extra thick one?
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
it actually has no base gasket on it in this picture
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
I have rebuilt many 2 strokes in my day. and have never seen a piston this far in the hole at tdc. don't get me wrong, this bike rips! this just looked a little off to me.
Vossman
Re: 95 kdx 200
Post by Vossman »
Keep us posted on what you figure out. Never see one that low.
Heres my old YZ motor.
pumpguy
95 kdx 200
Post by pumpguy »
Maybe someone put in the wrong piston or con rod. Did you happen to check the compression pressure before the head came off?
Is the piston crown this low @ BDC below the bottom of the exhaust and transfer ports?
cornishwrecker220
95 kdx 200
Post by cornishwrecker220 »
It's quite normal for there to be a gap .... I'm sure if you placed a ruler across the top of your piston it would be level with the top of the jug .... It also has to accommodate expansion .
Re: 95 kdx 200
Solder for squish measurement time??
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
squish without head gasket. . . . 148 thou , plus .010 for head gasket for a total of 158 thou or 4.013 mm
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
uh, yeah. Just looked it up , I'm about .100" over ! Lets start from the beginning.
I bought this bike for next to nothing, case was split due to a blown output shaft bearing (the one behind the front sprocket) guy said everything was there. well the crank and clutch was missing. no biggie. purchased a used crank off eBay along with a new rod and bearings sent this to RB to have it assembled, since he was doing my head and carb anyways. never had a chance to compare crank nor rod side by side so it looks like a wrong part was put in. piston is a stock piece. I guess this means I can run 87 octane has then ! I've been riding this bike for about 2 years this way. it runs good. I just gotta spin in like a 125 . oh well. I'm still gonna send it !
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
this is piston at bdc
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
jimmy97 wrote:this is piston at bdc
see picImage
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
see picImage
unless anybody has any advice before I re-assemble?
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
stroke is measuring right at 58 mm. it looks like the only thing it could be is the wrong length con rod was installed
jimmy97
Re: 95 kdx 200
Post by jimmy97 »
this is the exact rod that is in my bike now. looks like I was in a hurry and ordered the wrong year rodImage
Re: 95 kdx 200
If it is too short, how do you have proper compression?
Congratulations on your bravery and fearlessness to run a $49 connecting rod kit.
pumpguy
95 kdx 200
Post by pumpguy »
Wrong rod could be the problem. OEM rod # 13032-1210 is only listed for '95 & later H Series 200 & 220.
Looks like old man Murphy strikes again :sad:
david
Re: 95 kdx 200
Post by david »
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Re: 95 kdx 200
following photo from phospher site (good job to him!)
Since you gave about zero background info, did you just install the rod kit? What have you JUST done and how did it get to the point in the picture? Thanks.
Vossman
Re: 95 kdx 200
Post by Vossman »
Cool you got it figured out.
