Just tried to order a gear shift lever and shift rod for my 91 KDX 200. Shop called me back a week later and said shifter is on backorder and the rod is no longer made. Trying Babbitts next. Anyone have other suggestions for locating this? Part number 13161-1170
Thanks in advance.
Sent from my SM-N920V using Tapatalk
Shift lever and shift rod
patricktuller
Re: Shift lever and shift rod
Partzilla, you can enter oe part numbers in
Sent from my SM-G920P using Tapatalk
- 6 Riders
Order parts for the 95-06, should be the same as the kdx bottom end didn't really change much.
RockwoodKDX
Thanks I will try one of these if it gets kicked back from Babbitts
RockwoodKDX
Partzilla says the shaft is obsolete, will order the 95-06 part.
david
- Country: UNITED STATES
It's very possible that it's the same part. The difference that I can see is that the E series was sold as two different pieces, the shaft and pawl, separately. The H series was consolidated into one part number and the pieces show to be together on the parts drawing. There is a used H series on eBay for $30 and free shipping, that would be worth checking out. Maybe you can get a good enough look at it to compare to your to see if it will work.
http://www.ebay.com/itm/Shift-Lever-Sha ... Gx&vxp=mtr
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
RockwoodKDX
Confirmed, shift shaft no longer made. Got a shaft from a KX125. It is a little shorter but seems like it will work fine.
RockwoodKDX
Thanks, did not see this until after I purchased one for KX. In looking at the two, I am glad I bought the one I did. It is in perfect condition and I bought it with a lever for $50 total. Both in excellent conditiondavid wrote:It's very possible that it's the same part. The difference that I can see is that the E series was sold as two different pieces, the shaft and pawl, separately. The H series was consolidated into one part number and the pieces show to be together on the parts drawing. There is a used H series on eBay for $30 and free shipping, that would be worth checking out. Maybe you can get a good enough look at it to compare to your to see if it will work.
