Small Crack in cylinder - how serious?
Friedom
Post by Friedom »
It's little, but it's there - just by the main exhaust valve. Zoom in - below the main exhaust port.
How big of a deal is this? I had it open to replace the kips with BDK.. bike was running great upon disassembly.
eprovenzano
Re: Small Crack in cylinder - how serious?
Post by eprovenzano »
Wow this is a tough call. As I'm sure your aware it's only going to get worse with time. I think you know what needs to be done... It needs repaired.
1991 KDX basket case... being rebuilt
2001 KTM EXC 380... two stroke heaven
2000 KTM EXC 300, son's
1993 Kawaski Bayou 400 4x4
2008 Yamaha Vstar 1100 Silverado
Sullyfam
Post by Sullyfam »
It's not a big deal until it is, which is why I would have the cylinder fixed.
You will never be able to "guess" when the moment comes when that little crack creates bigger issues.
Friedom
Post by Friedom »
So in order to "fix" it, We're talking weld, grind, bore, plate, new piston likely.
Ugh. $500 crack right there. Might as well do port and polish too, hehe. Wish RB did plating, then I could send it to him to get dun right.
Sent from my SM-G930V using Tapatalk
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Friedom wrote:So in order to "fix" it, We're talking weld, grind, bore, plate, new piston likely.
That seems high. Plating should be around $200 and for some reason $50-$75 is standing out in my mind as the typical welding charge.
Friedom
Post by Friedom »
+ s/h you're right. Around @300.
Hard for me not to order p&p while they're in there, though. And should get a new piston while I'm in there. So.... $500 might make it.
eprovenzano
Yes... your all in costs for shipping (both ways), strip / weld / plate / hone should be around $250. Of course you'll have the cost of a new top end to add to that.
Sullyfam
Post by Sullyfam »
Yup, mine cost $260 all in (needed welding) from Millennium. Did awesome work. Two week turnaround. Sent them piston and they matched it to cylinder.
Friedom
Post by Friedom »
Wonder how I can determine the condition of current piston? It's pretty clean. Is that lazy to send it in for matching? Am I supposed to get new rings even though it had great compression?
Thanks for holding my hand, guys.
Friedom
Post by Friedom »
So Millenium's page says that a single cylinder repair is a flat rate of 274.95.
I'm waiting for an email back for verification. They did great work on my last engine, but there was no cylinder repair involved.
Tedh98
Post by Tedh98 »
Friedom wrote:Wonder how I can determine the condition of current piston? It's pretty clean. Is that lazy to send it in for matching? Am I supposed to get new rings even though it had great compression?
Unless you know the number of hours on that piston (and that number is low) I wouldnt risk a newly plated cylinder on a used piston.
Get new rings as well
Sullyfam
Post by Sullyfam »
Replate on website say is $209
http://www.mt-llc.com/serviceInfo.php?id=7
They charge an extra $60 if it needs welding, which yours will. When I called they quoted me $199 for replate and $60 for weld.
Repairs service I think is something entirely different I think.
Friedom
Post by Friedom »
I looked up the piston on it. It's a nice clean wiseco. Doesn't seem there's any way to assess condition though, eh?
Tedh98
Post by Tedh98 »
How many hours are on the piston?
Friedom
Post by Friedom »
With me? .25. I just got the bike running :)
History is that person A left it at a shop and didn't pay his bill. Person B bought it but it didn't run well. Person C bought from B to help with bills, and person C didn't really want it (has an H series) and couldn't get it working well due to "weak spark".
I'm person D. Turns out the stator was bad. After checking, testing and fixing other components I finally replaced the stator and it fired right up and ran like it should. Except for the broken KIPS, of course. Came to me with new plastics, light, tires, pipe and chain. The head gasket looked new when I opened it, piston too. Someone was throwing parts at it but didn't find the problem. Great compression too, 150+ iirc.
Jim B
Post by Jim B »
Friedom wrote:Image
Everyone's talking about replating. Isn't that a sleeved cylinder? (Looks like it from here. :hmm: )
Friedom
Post by Friedom »
Kinda does, huh? I'll get some better pictures to see if we can clear this up.
Is sleeving a cylinder a 1 way transaction?
eprovenzano
Friedom if the piston looks fairly new... I'd reuse it, but I would throw on a new set of rings I'd also monitor the run hours.
I can't speak to whether the cylinder has been sleeved... but I doubt it. Send it out and have redone to OEM Specs put in the piston with a new set of rings and let her rip
I'm sure you checked eBay... The only cylinder I found was over bored. I'm not a fan of over boring as you also need to cut the power valves to match. Personally I'd send your cylinder out to be repaired. It will be better than new when you get it back.
Friedom
Post by Friedom »
There's been some work done on this engine over the years. I see a C stamped on the exhaust flange, an 0916028 and 1125047 on top of the cylinder, a 1 near the kips arm, a 1028048 on the water outlet. All stamped custom, definitely not factory.
Going to post a few more pictures to see if it's sleeved or not.
Friedom
Post by Friedom »
