Kickstart fail
bultaco4ever
Kickstart fail
Post by bultaco4ever »
I have a kick start issue....it doesn't catch all the time. I searched a little on this forum and found this member described a similar situation.
"My kick start seems to "slip" sometimes. I have to kick it lightly until it catches. Is this normal? Its almost like I have to "line it up" before putting the foot to it or it will slip and I end up killing the top of my foot with the foot peg."
It's like I find a false neutral and kick through without moving the piston at all. My foot slams the bottom of the kicks stroke and hurts my instep.
I can bump start my bike easily but can't get it to kick start. I don't think I'm generating enough speed to the rotation. What should I look at to remedy?
ohgood
Re: Kickstart fail
Post by ohgood »
worn dogs on the assembly would be my guess. file them sharp again ?
bultaco4ever
Kickstart fail
Oh?.....you can do that?.....
Tedh98
Been thanked: 2 times
Re: Kickstart fail
Post by Tedh98 »
Don't hold me to this, but I think that is hardened steel. Might be tough to file.
Dekon
Kickstart fail
Post by Dekon »
You might want to check the plastic bushing in the spring. If it is not seated correctly it will do that. I went through the same thing this past winter after a full rebuild. The bushing looked like it was seated but it wasn't. Only took me three times to get it corrected.
bultaco4ever
Re: Kickstart fail
I watched a YouTube video of a guy who talks about the ratchet gear on his 84 KX. He said he used a Dremel tool to lightly sharpen the cog edges. It worked for a year til he found some good replacement parts.
ced64k
Re: Kickstart fail
Post by ced64k »
I had the same problem on a Gas Gas 200. Worn dogs on this ratchet :
I had to remove all the clutch to access it.
koshari
Re: Kickstart fail
Post by koshari »
Pain to get off. I fixed up a set with a fly cutter set up in a milling machine and had the dogs in an indexing head. The idea is to actually put a slight backcut on them so they pull in under torque rather than jump.
bultaco4ever
Re: Kickstart fail
Huh? I don't get most of the terms you just used. I'm a willing amateur mechanic. Can u explain?
Has thanked: 10 times
Been thanked: 17 times
Re: Kickstart fail
What oil are you using in the gearbox? Some heavier oils have been known to cause the ratchet gear to slip. I have a serviceable ratchet gear set if you find it needs to be replaced.
bultaco4ever
Re: Kickstart fail
10w30 I think. Save that ratchet set for me. I've started disassenbling. We ll see what we got.
koshari
Re: Kickstart fail
Post by koshari »
bultaco4ever wrote:Huh? I don't get most of the terms you just used. I'm a willing amateur mechanic. Can u explain?
a fly cutter is a tool that lets you mill flat surfaces,
and an indexing head allows you to accurately set up an object with multiple evenly spaced faces,
bultaco4ever
Kickstart fail
If I wanted to...where would I find these services?
bultaco4ever
Re: Kickstart fail
OK ....I removed the right side cover. So, in order to remove the kick start ratchet assembly, I have to remove the clutch basket first...right?
bultaco4ever
Re: Kickstart fail
Dekon
Kickstart fail
Post by Dekon »
Yes. clutch basket has to come out.
koshari
Re: Kickstart fail
Post by koshari »
iirc the hex nut on the clutch basket was a real pain to remove.
Bitteeinit
Re: Kickstart fail
Post by Bitteeinit »
Your search might have brought up some of my old threads. I first tried changing the spring, which didn't help. I then filed the grooves a bit which helped, but made it feel "fake". What helped best is changing my oil. I used to use 20w50, and switched to 15w40. It helped quite a bit. Still not perfect but much better. Forgot what the name is, but you could also try the old Ford oil (not available where I'm at).
Sent from my ASUS_Z00AD using Tapatalk
bultaco4ever
Kickstart fail
So, you went to thinner oil. I think I am already thinner than you. I forget exactly what the manual recommended but I think it was 10w30 or 10w40. I'm using one of those. I have the case off already and I'm trying to get the clutch basket nut off. I'm having a difficult time removing it so far. My little air compressor is too weak for my air impact. I made a flywheel holder that I'm going to try next and use some muscle. If that doesn't work I'm borrowing an electric impact wrench. I tried heating the nut a little with the air impact but it wouldn't let go.
Dekon
Kickstart fail
Post by Dekon »
A Harbor Freight electric impact gun is a real life saver when it comes to working on these bikes. Zips the clutch nut right off.
