la sleeve
jimmyjamez1212
la sleeve
Post by jimmyjamez1212 »
Has anyone attempted sleeving? L.A.sleeve sells one. I'm ordering one to see what my machinist things.
Has thanked: 10 times
Been thanked: 17 times
Re: la sleeve
Yeah, it's been done quite a bit. Why do you need it? Is the cylinder just thrashed?
jimmyjamez1212
la sleeve
It's just scuffed up. But I can get the sleeve and it installed for cheaper than getting it plated and the sleeve well last a Hell of allot longer.
Re: la sleeve
That's not quite right. An aftermarket re-plate should last as long as you own the machine, barring any catastrophic failure. A sleeve will require honing / boring with each new piston install. Also, by the time you pay a shop to bore and press in the sleeve, the cost will be close to a strip and re-plate. Also consider that in a plated cylinder, it is impossible to bore and install a sleeve without affecting port timing. Then you have to also worry about the liner shifting at some point in the future. Honestly there is zero benefit of a sleeve over plating unless the cylinder is damaged to the point of having to be bored or welded to repair it.
sarrant
la sleeve
Post by sarrant »
A sleeve will not last longer and even in a best case scenario (perfect install) has some inferior performance characteristics.
jimmyjamez1212
la sleeve
It will cost me the same for the sleeve and and labor as the plating. He said he can match the sleeve exactly to how it is now. Plus the cylinder is egg shaped. Measurements are from 65.2-66.5. I have two engines. Might do one each way and see the differences for myself.
Has thanked: 126 times
Been thanked: 33 times
Re: la sleeve
no way in hell it is 1.3 mm different. :naughty: :shock: :lol:
initial cost may be the same, but long term is more expensive.
Kawasaki has been doing it for 40+ years.
Tedh98
Been thanked: 2 times
la sleeve
Post by Tedh98 »
jimmyjamez1212 wrote:It will cost me the same for the sleeve and and labor as the plating.
Then it is a no brainer - plate it!
jimmyjamez1212
la sleeve
Sorry, 66.2 66.5. I believe it was. Like I said I have two engines. I'm pulling the other one now.
