does the head have to be "broke in"?
ckelly33
Will your bike really run different until you break the head in?
- Tedh98
- Been thanked: 2 times
pumpguy
When you say "head", do you mean cylinder head, the part that bolts to the top of the cylinder above the piston, or something else?
If you really mean cylinder head, the answer is no. If you mean cylinder and piston, then yes, the engine should be operated carefully for a while until they're broke in.
- Tedh98
Or you can get the engine up to operating temperature and then run the snot out of it. Sorry, I couldn't resist.pumpguy wrote: the engine should be operated carefully for a while until they're broke in.
- IDRIDR
Tedh98 wrote:Or you can get the engine up to operating temperature and then run the snot out of it. Sorry, I couldn't resist.pumpguy wrote: the engine should be operated carefully for a while until they're broke in.
I've wondered if MotoMan's Break In Secrets apply to 2T. Why wouldn't they?
http://www.mototuneusa.com/break_in_secrets.htm
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- Tedh98
Re: does the head have to be "broke in"?
This is a topic that could easily fall into the "which oil to use" type of debate. In the end you have to go with the approach that you are comfortable with.
With that being said, I've been doing the hard break in for years with only success and no problems. It makes sense to me.
- KDXohio
Will definitely turn into a debate now!
- adam728
Not if the op really means cylinder head. No break in on that.
As for Motoman's method, its not bad, but man that guy likes to toot his own horn. The whole website reads like he's the smartest guy in the universe because he does things differently. And hardly any real data to be found anywhere either.
- Sullyfam
Or maybe he IS a genius because there are no facts to prove he is not!? [emoji12]adam728 wrote:Not if the op really means cylinder head. No break in on that.
- fuzzy
Been discussed to death on here since the dawn of this site. I'm a proponent of rapid break-in. I like to call it ring seat instead of break in, because that's all you're doing. If you're breaking in another part, you did something wrong (in this day and age).
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
- Has thanked: 10 times
- Been thanked: 17 times
I concur, completely.fuzzy wrote:Been discussed to death on here since the dawn of this site. I'm a proponent of rapid break-in. I like to call it ring seat instead of break in, because that's all you're doing. If you're breaking in another part, you did something wrong (in this day and age).
ohgood
IDRIDR wrote:Tedh98 wrote:Or you can get the engine up to operating temperature and then run the snot out of it. Sorry, I couldn't resist.pumpguy wrote: the engine should be operated carefully for a while until they're broke in.
it started out as just a joke, but then people started to believe it, and argue about it, so he's laughed his ass off about the unintended troll for years now.
There are similar methods described in automotive publications, as well as aviation and high performance race publications. The one thing they have in common with Motoman is heavy throttle at varying (high) RPM, and the importance of seating the rings as quickly as possible. Regardless of your opinion of motomans article, there are plenty of other sources of similar information. Just like any other debatable subject, you can find loads of information to support whichever method you wish to validate.
pne
his method suggests that within a few miles your crosshatching is all worn down and there is nothing left to seat the rings. Yet how many motors have you seen torn apart where the cross hatching looks perfect? If the hatching really wore that fast the only way to properly do a top end would be to hone the top end each time new rings are put in. With nikasil lined cylinders they are so dam hard thats not necessary.
- adam728
His method talks about glazing the cylinder, I believe. So it's not about the cross hatching being worn off, but rather glazed over so it cannot then be utilized.pne wrote:his method suggests that within a few miles your crosshatching is all worn down and there is nothing left to seat the rings. Yet how many motors have you seen torn apart where the cross hatching looks perfect? If the hatching really wore that fast the only way to properly do a top end would be to hone the top end each time new rings are put in. With nikasil lined cylinders they are so dam hard thats not necessary.
