Powering multiple items with stator output
Hey guys I am wondering about how to power multiple items on my bike. I have a 35w headlight and a 10w tail light/5w brake light, and would like to add a horn, and led strips for license bracket+turn signals. The stock stator is around 45w so I need more power, so I am thinking I need a battery or capacitor otherwise get a more powerful stator, which is harder. The positive and negative currently go right to the lights, so that would go to the capacitor/battery if used and whatever out from there. What is a good battery or capacitor to use or should i try something else? Any info will help thanks.
Re: Powering multiple items with stator output
I could be wrong,but I don't think the stator is anywhere near 60w..
I changed that because I remembered it was 45w sorryGI_JO_NATHAN wrote:I could be wrong,but I don't think the stator is anywhere near 60w..
- Postigo
Hi, first do the stator rewind, buy the tusk street light kit, a $4.00 radio shack rectifier and a $10.00 lead sealed battery at eBay. The set up works really good and is maintenance free. Here is the tread: http://www.kdxrider.net/forums/viewtopi ... 77&t=16580
Interesting.Postigo wrote:Hi, first do the stator rewind, buy the tusk street light kit, a $4.00 radio shack rectifier and a $10.00 lead sealed battery at eBay. The set up works really good and is maintenance free. Here is the tread: http://www.kdxrider.net/forums/viewtopi ... 77&t=16580
Thanks.
Hey thank you for that. It has a lot of useful information. Would a stock stator not be enough to charge the battery?Postigo wrote:Hi, first do the stator rewind, buy the tusk street light kit, a $4.00 radio shack rectifier and a $10.00 lead sealed battery at eBay. The set up works really good and is maintenance free. Here is the tread: http://www.kdxrider.net/forums/viewtopi ... 77&t=16580
- Postigo
I don't think so, look for stator rewind by slick nick for instructions on how to do it. Is cheap and easy or you can buy one from Ricky stator for around $80 instead of $10 by doing it yourself. Another benefit of the stator rewind is that you will have better illumination for night riding.
- Been thanked: 6 times
Stock is 40 when going at high RPM. We wish 45.
Damn. Well I will be rewinding it soon then.Jason wrote:Stock is 40 when going at high RPM. We wish 45.
- Has thanked: 5 times
- Been thanked: 10 times
http://www.steahlyoffroad.com/lighting/ ... -coil.html
That works well, also. I haven't tested it's output, but I suspect the advertised rating is on the conservative side.
Does anybody know if there is an option to slim down the air filter? I need to make some room for a battery and the stock (i think) air filter is really bulky.
- K50X200
The Baja Designs D/S kit uses a small battery pack (the battery is really only needed to run the horn - it's a power hog) which is made up of AA batteries wired in series.
When I bought my plated KDX (with a BD D/S kit installed) the battery pack was shot so, I rewound the stator and soldered up my own battery pack from these (3000mah vs B/D's 700mah):
http://www.ebay.com/itm/Brand-New-12-Pa ... 1e7d42210d
I've been running this set-up for two years with no problems... I do use a Battery Tender Jr. during storage to keep the battery pack topped off - and learned after using the Ni-MH batteries that they may not be the best for the task do to a limited lifetime, but have had no problems thus far. The BD D/S kit tucks them up behind the headlight...
Don't know if this'll work for your situation - but it is a big space & weight saver!
"00 KDX200 - Baja Designs D/S Kit, '03 KLX300 Forks, KB5 Suspension Mods, Keihn 35 ASQV, Boyesen Rad Valve, Gnarly Woods Pipe
