Hello All,
Further along in the process with my KDX250 and I have an electrical question. This could relate to all KDX models, which is why I posted out f the model-specific section.
Is the output of the lighting coil AC or DC in the stock configuration? I'm considering running LED tail lights and possibly Cyclops LED front lights, and I know they require DC...and thus a full-wave rectifier if stock coil output is AC.
Anyone out there familiar enough to provide a clue?
lighting coil output & LED bulbs
- dingerjunkie
Theory and Practice are ALWAYS identical...theoretically...
http://www.fire-fx.net
...your theater is on...
- IDRIDR
Re: lighting coil output & LED bulbs
Timely question for me as well. My new-to-me 220 has no lights but I'll be adding some. Likely an LED tail light and a used Trail Tech X2 halogen and perhaps an extra LED light bar up front.
I think the output is AC but let's hear from the pros. I saw on another forum someone installing an AC to DC converter instead of a rectifier.
I'd like to see your Cyclops when its up and running.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- Been thanked: 10 times
It is an AC output with frame as ground. To covert to a battery enabled system you have to float the ground from the lighting stator off the frame and rework all your lighting to route all the grounds to the negative terminal of the battery. Not difficult to do. A rectifier is an AC-DC converter. To run LEDs you could just wire a rectifier in a half-wave configuration then you don't have to worry about changing grounds or adding a battery (though a battery helps smooth things out electrically).
- dingerjunkie
Thanks...will plan on wiring in a rectifier...no battery desired.
- ss109
- Has thanked: 33 times
- Been thanked: 57 times
Unless the LEDs have an electronic controller you can run them on A/C. I know this works as I have run LEDs off of the stock A/C system on my KDX. Remember, a rectifier is basically a series of diodes which LED's are (LED = Light Emitting Diode). Just wire in an appropriate sized capacitor to help smooth out the current. Simpler and cheaper!
- IDRIDR
Good to know, thank you.SS109 wrote:Unless the LEDs have an electronic controller you can run them on A/C. I know this works as I have run LEDs off of the stock A/C system on my KDX. Remember, a rectifier is basically a series of diodes which LED's are (LED = Light Emitting Diode). Just wire in an appropriate sized capacitor to help smooth out the current. Simpler and cheaper!
What about halogen bulbs? http://www.trailtech.net/lighting/halog ... ht_type=48
How do we determine the appropriate capacitor size?
2014 Suzuki DL1000.
2014 Suzuki DL1000.
- ss109
Halogens will run on A/C. I'm not really sure on how to pick a capacitor. My lights worked well enough I didn't use one but was told it could help if I needed it. I would look for something online to figure it out or talk with an electrical guru. IIRC, we have one or two members that are electrical gurus.IDRIDR wrote:Good to know, thank you.SS109 wrote:Unless the LEDs have an electronic controller you can run them on A/C. I know this works as I have run LEDs off of the stock A/C system on my KDX. Remember, a rectifier is basically a series of diodes which LED's are (LED = Light Emitting Diode). Just wire in an appropriate sized capacitor to help smooth out the current. Simpler and cheaper!
