Quick cylinder qeustion about cleaning
Ryan
Post by Ryan »
i am talking by cylider apart to rebuild the top end. Well everything id covered in a ton of spooge. I mean a ton ton. Im not sure how to clean all this out, it is in my kips and under the other cover on the cylinder. CAn i just let it sit in parts cleaner over night???
Has thanked: 153 times
Been thanked: 38 times
That sounds a bit harsh. Grab an old toothbrush and try that. If any part is made of just steel, use oven cleaner on it. If you are in doubt, or it is aluminum, spray it on, but let it set for no more than 10 minutes. It can start to eat the aluminum.
In general, I suggest you use the least harsh method, then increase from there.
skipro3
Post by skipro3 »
Page 176 of August 2005 DirtRider has a good article with tons of photos on Power Valve Cleaning.
(I knew there was a reason I keep the old copies next to the toilet!!)
Jerry
Mr. Wibbens
Post by Mr. Wibbens »
Yamaha Combustion Chamber Cleaner
Great stuff, try it!
Ryan
Post by Ryan »
can i use like brake cleaner in a can?? or carb cleaner??
wanaride
Post by wanaride »
I'll second Wibby's recommendation for Yamaha Combustion Chamber Cleaner. I tried it in my S/A and the spooge just dissolved away.
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
Ryan
Post by Ryan »
well i got my power valves and the kips apart today, everything was spooged and some pieces had at least 1/5 of carbon build up. And im not exaggerating. Anyway, i took a wire wheel and hooked it up to the drill press and got it off. I got some brake cleaner and parts cleaner. The parts cleaner takes the spooge off but the carbon can only be take off by the drill press. Now i just got to get a top end.
Colorado Mike
Post by Colorado Mike »
What exactly did you clean with a wire wheel? The KIPS valves?
Mike
'04 KDX220
Ryan
Post by Ryan »
parts of the valve. there are two parts that go into the cylinder which had alot of carbon. thats what i used it for. Now it looks all new :grin:
canyncarvr
Post by canyncarvr »
Uh-oh.
Those parts aren't made from Cubic Zirconium!! :wink:
The parts may look good...but I would be surprised if they aren't damaged.
re: Yamaha cleaner
I asked about that at the local Yamaha shop...didn't see it on the shelf. 'Got some?' I said.
'No,' they said.
Gee...that was easy! They wouldn't order it, neither!
KDXer
Post by KDXer »
I got a product called Subaru upper engine and combustion chamber cleaner. Awesome stuff !!! Can't praise it enough. Carbon and spooge basically wiped off. A bit pricy over here but any Subaru dealer should be able to get it. Give em a call first though to avoid disappiontment.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I use Alka-Seltzer Plop Plop Fizz Fizz....
http://www.wackyuses.com/alkaseltzer.html
Ryan
Post by Ryan »
trust me this carbon was caked on, i tried professional parts cleaner, and it did nothing. The parts look great with no pitting at all.
Ryan
Post by Ryan »
i have another quick question, why does my cylinder have a 'B' stamped on it?? It is small and very close to the head.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Because it's a "B" sized cylinder... most of them are.
Ryan
Post by Ryan »
is this a good thing or bad?? whats the differnce between the b and the a?? thanks
m0rie
Post by m0rie »
The size of piston that is optimal for the cylinder corresponds to the letter stamped on the cylinder.
1989 KDX 200
2007 TTR-50E
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It's a normal thing. You see... there are A , B , C , and D sized pistons for any given bore. A is what the machine that makes the piston is set at but as tooling wears, specs start changing. They just make sure to match up the piston to that sized cylinder.
A is smaller than a B etc... :grin:
P.S... If you buy a Wiseco, they only make one size... just make sure you size the ring to your cylinder.
Ryan
Post by Ryan »
so i cant just get the normal rings for weisco??
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It's a piston kit.
