So I just bought a 2003 KDX 200 and noticed that it leaked exhaust where the pipe enters the jugs. It was black and oily all over. Took off the pipe and saw bits and pieces of what was left of an o ring. I also noticed that I didn't have the aluminum/copper gasket that goes in between the pipe and cylinder. I clean the area and noticed because of that the pipe has worn grooves in the area. Do you think just getting a new exhaust gasket set will fix this?
Any help would be appreciated!
Austin
exhaust leakage problems
Corey
Re: exhaust leakage problems
I would definitely get the new gasket and o-ring. Also, buy some hi-temp sealant that withstands petroleum applications and apply around the pipe in the area where it would be halfway in/halfway out of the exhaust flange.
s10gto
- diymirage
the "worn grooves" are in the very head of the pipe right ?
there should be two of them and they should have O rings on them
how are your springs looking ?
they tend to loosen up in time and that can keep the pipe form fitting tight aswell
-1997 KDX 220 project bike
GoJarvis!
- diymirage
yes BUT you need to address the compression issues firstGoJarvis! wrote:I have the same problem except mine is a 1993... Same solution?
no point in doing it twice
