New 220 owner (update: bike fixed)
Re: New 220 owner (update BLOWN UP)
Thank you for the info, and responding so quickly. It is very much appreciated!
- rbates9
Good luck with it. I see there is a brand new 220 cylinder on ebay... But they want 499 for it.
- Postigo
Here in the site is a guy with a spare 220 cylinder that want to trade it for a 200 cylinder maybe he is able to help. Here is the tread. http://kdxrider.net/forums/viewtopic.ph ... 00#p134937
- diymirage
I would recommend langcourt
I had them work on my 200 cylinder
they rebored it and replated it and did a great job on it
off course, since yours is a 220 to begin with there may not be enough meat left to rebore but they can definitely look at it and reweld it
-1997 KDX 220 project bike
Sent the cylinder out to millennium today. I wanted to do an exchange to save time, but they currently don't have any in stock.
- fuzzy
They both do great work, you'll be in good shape
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Re: New 220 owner (update: blown up)
What do you guys generally do for a fresh top end break in? I know what the manual says
If you put a forged piston in make shure you heat cycle it first, then constant throttle change to seat the rings. Cast just constant throttle change.
- rbates9
Fire it up, let it warm up, check for leaks, shut off and recheck levels, ride it like you stole it. Just the way I do it. If you spend the time doing all the heat cycles and playing with the throttle it will be due for a new top end before you get to ride it.
rbates9 wrote:Fire it up, let it warm up, check for leaks, shut off and recheck levels, ride it like you stole it. Just the way I do it. If you spend the time doing all the heat cycles and playing with the throttle it will be due for a new top end before you get to ride it.
That's what my buddy helping me with the rebuild said. I wasn't sure though. Thanks
Bike is up and running great! Judging by the amount of power it has now, the engine was damaged before i bought it. The bike had been sitting, for awhile prior to me buying it, so i thought the rough running was just a gummed up carb, and a bike in need of some tlc. It wasn't, but atleast i have a nice engine now
Thanks everyone for the advise.
