Case splitting.
Case splitting.
I can tell you I wish I would have used the crank installer tool. I tried the heat/cold on the right side and it worked perfectly. Unfortunately it wasn't the same for the left side. I know it isn't a "must have" tool but if I ever split cases again I will be using one!
Re: Case splitting.
Now someone do a poor mans version ;)
- scheckaet
Case splitting.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- CoronasAndChips
Re: Case splitting.
That's the multitool that comes with all Harley Davidson Products since about 1975.
Elbow grease contains no trans fat!
CoronasAndChips on XBox Live
BFBC2, BF3, COD 2,3,4, Black Ops, Red Dead Redemption, Tiger Woods 08' and 09' and Forza 2..... mostly
- rbates9
Re: Case splitting.
kyledsmith87 wrote:Now someone do a poor mans version ;)
What part or parts of it need to be economized?
- scheckaet
Case splitting.
am guessing the 3 tools I mentioned a few post before...flywheel remover, the case spliter and the crank removal
good luck with that...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Case splitting.
This is a great write up. I have split lots of 2 stroke cases, but I have never used a crank puller, or a case splitter. I always managed to get the job done with a soft mallet, and some patience. There have been occasions where I wish that I did have the right tools, though.
On some motors, it is very easy to miss the removal of a case screw, and you will not get very far if you do that.
I hope to fully tear down my '04 200 this winter.... but, I said that last year.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
- scheckaet
Case splitting.
is there a trick to remove the bearings from the crank? both of them are stuck on it Can't seem to find a proper bearing puller .
thx
thx
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Case splitting.
Throw that whole thing in the oven and get it good and hot. The bearings seem to expand faster than the crank spindles and should come right off after some heating.scheckaet wrote:is there a trick to remove the bearings from the crank? both of them are stuck on it Can't seem to find a proper bearing puller .
thx
- scheckaet
Case splitting.
damned! i did the opposite, threw it in the freezer
was gonna heat the bearing with a propane torch and see if i could get them out.
i might try it anyway since it's already frozen cold.
thx
thx
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Re: Case splitting.
If it's cold, heat the inner bearing races with a torch, and they should pop right off.
Case splitting.
Yep! Just grab a'holt of 'em with your finners after you take it out of the oven (using only your hands, of course) and PULL 'em off!!Juliend wrote:Throw that whole thing in the oven and get it good and hot. The bearings.....should come right off after some heating.
My method of getting the bearing(s) off the crank was very simple....for me.
I sent the whole mess to Mr. Black.
Case splitting.
hahaha! Actually, I took it out of the oven using oven mitts, placed a large flat screwdriver between bearing and crank half, and just gave it a little tap. If you take it out and grab the bearing with your fingers, please get video.canyncarvr wrote:Yep! Just grab a'holt of 'em with your finners after you take it out of the oven (using only your hands, of course) and PULL 'em off!!Juliend wrote:Throw that whole thing in the oven and get it good and hot. The bearings.....should come right off after some heating.
- kawagumby
Re: Case splitting.
If the heat doesn't work, you can get bearing removal tools (the tapered wedge kind that will bolt together) from harbor freight pretty cheap. With those, usually the bearing will come off simply from tightening up the two halves, if that doesn't work you can then use a puller.
- scheckaet
Case splitting.
what oven temp do you all think I should use to heat the cases? (ready to install new bearings)
I don't want to burn or damage the new seals.
thx
thx
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
Case splitting.
Typically about 230F will be plenty to set a bearing but with a seal in there too I would say probably about 200 would work ok. When you get the bike hot enough to boil over while riding it is probably that hot near the seals.
When you heat the case to fit a bearing you are looking for the temperature difference between the case and the bearing so if you freeze the bearing in the freezer (about 0 deg.) then heat the case to 160 you would have about the same difference as a room temperature bearing (70 deg) in a hot case (230 deg). And 160 is well with in normal heat ranges for a seal.
- scheckaet
Case splitting.
thanks I'll try 200, my bearings have been in the freezer since i received them last month, that ought to be enough
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
Case splitting.
Rbate, would you care to explain how this works???
I got the same puller and for the life of me I can't figure out how this would even work???
On another note, do I have to remove the new gasket (yamabond 4) and put fresh stuff since it's already on and I'll take a few days before I can press the case halves together???
thx
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
Case splitting.
I replied to your PM. Let me know if that helps.
- scheckaet
Case splitting.
Rebates wrote:
The crank puller should have come with two "nuts", one will screw onto the crank and the other is the wrong size. (For a different size.) When you get the correct size nut for the crank there is an adapter that goes on the eng of the puller screw. The Nut goes inside the adapter then onto the puller shaft. Screw the shaft with adapter onto the crank then slide the tube part of the puller down on the pulling shaft, start a nut and as you tighten the nut on the puller rod it will pull the crank into the case. While it is pulling just watch the gap and try to keep it going down as square as you can. I can't remember for sure but I think the key way for the flywheel may need to be removed when you are pulling the crank in.
Yes, you will have to clean the sealant back off and put new on.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
