Link to Kawasaki Japan
http://www.kawasaki-motors.com/parts_cat
If you can interpet Japanese or somehow navigate through the site, this should have what you are looking for. (Thanks JasonWho! )
A site to translate Japanese to English http://babelfish.altavista.com/
Here are some basic instructions.
Toward the top left, click Motorcycle.
The first drop down menu has the various models listed in English.
The line below that is From, To and Go. Just choose which model and Go.
A list of various years will then be at the bottom. Choose your model.
On the page that comes up, diagrams can be seen one at a time or several at once in a grid format. If you choose grid format, you can save the pictures from there. The top drop down box is single. The next drop down box is grid format.
You can scroll left or right through the singles or grids.
I hope this helps,
JasonWho
I hope this helps,
JasonWho
I have used the above link quite a lot and found it a bit of a pain, try this link below, it's very easy to use and a lot of the part number have been updated, also if you go to the home page, you can get the same system for other Kawasaki models
http://www.megazip.ru/ru/bike/kawasaki/view/744
Thanks for the link! i have a question though, if parts number is the same on different bikes, does that mean does parts are the same and can be used on each bike? I've compared the 92 E and the 92 SR.petrolhead wrote:I have used the above link quite a lot and found it a bit of a pain, try this link below, it's very easy to use and a lot of the part number have been updated, also if you go to the home page, you can get the same system for other Kawasaki models
- rbates9
If the part number is the same then the part is the same. Different year, model ect.
Re: Link to Kawasaki Japan
That's good to hear then! pistons are the same for both series.
- Country: UK
Here is a direct link to the SR (and other bike) schematics:
http://www.kawasaki-motors.com/for_user ... earch.html
and a quick guide on finding what your looking for:
hope this is helpful to someone
Thanks! As you can see from the dates, it has been a while.
- jstcraig
- Country: Australia
Wow these are great, too bad I’m 10 yrs to late lol, found the Russia site easier to use, this will be a valuable resource all the same
- Country: Japan
Every link and photo in this thread appears to be broken. I have a Japanese girlfriend I will try to find an updated link
