Chain & Sprocket Question
- Fatherof2
Hi Gang,
I just turned 400 miles on my KDX, and the stock chain is about done. My clamshell is on 9, and the chain is just barely in spec. I was surprised by how much it has stretched out.
Should I replace a stock rear sprocket with only 400 miles on it while I am replacing the chain? It appears to be in decent shape.
Will an X ring chain require a different chain guide? Mine is stock.
I am thinking of going with this set up:
http://www.rockymountainatvmc.com/produ ... yPart.y=10
Is that a good call?
Thanks for any input,
David
David
- scheckaet
[oring are wider and require a wider chain guide. dunno about x ring.
i change everything together chain + sprocket for the reason mentioned above.
The stock chain is just garbage, it would stretch every ride (20 miles). Any other will also stretch the 1st few ride but then it stops.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
Might be the case on some but I think the stock guides are the same on a 200 (non o ring chain) and a 220 (o ring chain).scheckaet wrote:[oring are wider and require a wider chain guide. dunno about x ring.
If you need a new chain you will want a o ring or x ring chain so buy it and see if it fits! If it won't fit the guide the FRP I know has plenty of room.
As far as brand of chain and sprockets it is up to you as far as how much you want to spend. Personally I would stick with steel sprockets because they are cheaper and tend to last longer than some of the aluminum sprockets.
- Fatherof2
- rbates9
I had a 95 200 years ago with a stock guide and a o ring chain. The bike I have now is a 2000 with a X ring chain (it had an o ring when I bought it.) and the bike came with a FRP chain guide so I do not have an OEM to compare it to.
scheckaet and juliend are saying that you need a new guide so they may be right. If time down is an issue than I would order a aftermarket chain guide just to be sure.
One of the guys I ride with had a bone stock 06 200 and put an o or x ring chain on it with out changing anything so I would like to know if you need a new guide or not. Might be a year difference in the H's.
The part numbers are the same for the guides from a 220 to a 200 but maybe they just don't bother with the 200 guide for replacement parts.
Good luck.
Good luck.
- Fatherof2
makeshoes
- Fatherof2
- Mr. Wibbens
It'll just wear fasterFatherof2 wrote:
Can anyone confirm with certainty that the stock chain guide will work with the X ring chain? I may as well try and use the stock one if possible. It seems to work fine. Looks fine too.
Thanks again,
David
You might want to buy an extra clip or two (should carry one extra anyway)
The clip wears down until it's pretty much paper thin
- scheckaet
i second that on the clip. I always have 1-2 extras
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Brian
If the stock chain guide is rubbing on the chain side plates you can loosen the screws along the bottom and if necessary put a small washer between the aluminum and plastic to open it up a little.
If the screws that hold the sides of the guide are too tight it compresses the plastic a little and causes friction on the chain side plates.
I run my screws a little loose and use locktite to keep them from backing out.
Or just get an aftermarket chain guide.
