cylinder stud torque
wvsp612
Post by wvsp612 »
Just got my replated cylinder back from Millenium. Looks great. Anyone know the proper torque for the cylinder studs? I searched on here but to no avail. I also have the cyclepedia manual, but i don't see it listed there either unless you just use the general torque values. Anyone?? :?
Cody
2003 KDX 200
wvsp612
Post by wvsp612 »
C'mon, someone must have sent their cylinder in to be replated and then had to reinstall the cylinder studs. A little guidance?
Cody
2003 KDX 200
Has thanked: 30 times
Been thanked: 46 times
I don't subscribe to the Cyclepedia manual but I would think it would be in there. I know the factory manual has them listed at the beginning of each chapter plus in the individual service procedures.
Oh, BTW, you never mentioned what KDX you have. :mrgreen:
Varmint
Post by Varmint »
For E Series bikes the torque spec is 18ft/lbs (25 n-m) for the cylinder head nuts and cylinder nuts. Be sure to tighten in a criss-cross fashion.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
wvsp612
Post by wvsp612 »
OK, so the torque for the cylinder studs themselves is the same as the torque for the cylinder stud nuts? Thanks
Just wanted to be sure. I found the torque for the nuts was 18 ft-lbs, but I did not see the torque for the studs themselves. :supz:
Cody
2003 KDX 200
Mr. Wibbens
Post by Mr. Wibbens »
wvsp612 wrote:OK, so the torque for the cylinder studs themselves is the same as the torque for the cylinder stud nuts? :supz:
Where'd you see that?
Varmint
Post by Varmint »
My bad. I said E series but I meant H. And yes my manual says 18ftlb for cylinder and cylinder head nuts.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Mr. Wibbens
But not for the studs :wink:
rbates9
Post by rbates9 »
Probably about 12 ft.lbs for the studs. Do you have a book? The studs just need to be bottomed out good so they won't loosen up later. the torque from the nut will also help hold it in place.
Mr. Wibbens
I googled the **** out of this
Consensus seems to be you don't need to torque the studs
Dissimilar metal electrolysis will tend to make a stud 'stick' in the head
KarlP
Post by KarlP »
I've always just screwed 'em in till they bottom then back off a 1/4 turn.
Never worried about it too much.
'08 KTM200xc
KX100 for the boy
